Cam install; before and after numbers?
I'm wanting to install a cam and would like to know what your hp was after the cam install? I'm talking about a bolt on car with a cam. Also list what cam you used to get that power. Cams make my head spin so I'm trying to narrow down my options. Thanks
Originally Posted by Gmzo6
(Post 1583162090)
Large cams will give you more peak HP. Moderate Tq gain. Really great on road courses where your in the high RPM range all the time. They sound great too ! Requires a little more tuning expertise to get them drivable. Medium sized cams will give you a good HP increase but will give you more of a torque gain over large cam's. More drivable all around. More usable power for regular driving. Easier on the valve train components too. Toque Here is what I did.... http://www.toquez06.com/dyno/dyno.jpg |
Stock 98 LS1 A4 with 3.15 gears Bolt ons and a handheld tuner! 323 RWHP
Head and Cam and Long tube headers and 3.42 gears with 3200 stall - 423 RWHP Cam: Comp Cams 224/228 581" 588" 114 +2 Heads: TFS 215's Thanks,Matt |
2000 Auto with 3.15 gears
Stock...291.04 Hp and 301.34 Tq Tuned 303.09 Hp and 316.05 Tq weather was between 70-74 degrees and 17% humidity. Added Mods Street Sweeper HT Cam..228/232 .600/.612 111 LSA Lunati Gold Dual Valve Spring Kit, JP Double Roller Timing Chain and Manley Chrome Moly Push-Rods,Comp Cams LS Trunion Upgrade Kit . Also added LS6 intake, Ported TB,Powerbond Underdrive Crank Pulley, Long tube headers with highflow cats and Corsa Exhaust, SLP Blackwing cold air and a PI 3400 Stall Converter. 373Hp /341Trq |
Did the cam and heads at the same time but,
long tubes and mail in tune 330hp 228R cam, PRC 5.3L heads shaved and cometic gasket 11:1 compression ported FAST 78 with ported TB and vararam (although not visible on the dyno) 445 rwhp |
Does anyone know about the England green cam kits?
