Low tire pressure warning system
Have a 96 and am thinking about changing the standard rims to different rims. Is the LTPWS device on the standard rims transferrable
to the new rims or do I lose the LTPWS. If I lose it, the warning light will probably remain on all the time, correct? |
Originally Posted by Grandpabill10
(Post 1583170481)
to the new rims or do I lose the LTPWS. If I lose it, the warning light will probably remain on all the time, correct? Regarding the light. That's debated from time to time. It's thought that '93+ will leave the light lit. Removing the bulb/s is considered a fix or I believe just disconnecting the module will accomplish the same. How easy is it to access the module in a '96? Don't know! |
