FS 2 piece C6 Z06 front rotors-hats only
2 hats only Performance AFX alum hats.
Excellent condition. $125 for the pair plus shipping from Fl 32550. I'm selling a few items and getting ready for the C7. http://shop.performanceafx.com/C6-Fr...100166-167.htm http://i411.photobucket.com/albums/p...ps5f244a2b.jpg http://i411.photobucket.com/albums/p...ps1566afc6.jpg . |
Fixed or Floating style?
Originally Posted by yooper
(Post 1583262616)
They are to replace the stock Z06 rotors that work with the stock style fixed calipers. Hope that answers your question. :thumbs: |
Originally Posted by *C7*
(Post 1583264704)
Bill |
(Post 1583269604)
....Also have a selection of heavy duty or regular.
Bill Do you know if either the regular or heavy duty rings will work with these rotors? Or at least with the hats you have, can you use either/or with your hats? I might be interested in these if I could use both the regular and heavy duty rings. TIA, Bob :flag: |
The hats I have for sale are from AFX fixed standard rotors. The are the exact ones the link in the first post takes you to.:thumbs:
I do not know if they will interchange with the floating or heavy duty rotors. |
Originally Posted by BEZ06
(Post 1583269887)
Hi Bill
Do you know if either the regular or heavy duty rings will work with these rotors? Or at least with the hats you have, can you use either/or with your hats? I might be interested in these if I could use both the regular and heavy duty rings. TIA, Bob :flag: The only way to know is to call Bob Finlayson at AFX. Bill |
Would you be willing to sell one? If not, could you tell me what the dimension is between the center of two outermost mounting screws (to the disc) and the dimension between one outermost mounting screw and an adjacent one? I know that might sound strange but I have a ring I would like to know if it would mount to this hat. (Not for actual vehicle use.)
Originally Posted by PCMusicGuy
(Post 1583273734)
I will measure tonight and get back to you. |
The hats will work on the heavy duty, standard and floating design.
Bob |
(Post 1583273734)
The distance between 2 adjacent holes is a fat 2 1/8" and the distance across the hub to the center of the mtg. holes is 8 1/4". Hope this helps.:thumbs: |
(Post 1583279077)
pm sent. consider them sold.
:cheers: |
Originally Posted by NVR2L8
(Post 1583288758)
:cheers: |
