69 Parts List - First Come First Served
These are all parts from my barn find 69. Over 95% of the parts listed are direct from this 350/350HP vette... I went my own way with the build and did not use most the original parts.
SEE PHOTOS HERE: http://sdrv.ms/XHfuV6 PayPal only. Sorry guys but don't wish to deal with checks or cash. Payments can be made bdchase73@gmail.com. PLEASE NOTE THE ITEM NUMBER WHEN ASKING OR PAYING FOR PARTS ON ALL CORRESPONDENCE. Thanks! Item - Description - Price New - Price Used 1 OEM Interior Wiring Harness & Engine Harness $689.00 $250.00 REDUCED! - $150 2 OEM Door Harness (Power Windows) $159.00 $100.00 REDUCED! - $50 3 OEM 350/350 Distributor (Fully Rebuilt W/New Parts Original Distro REBUILT NEVER USED) $399.00 REDUCED! - $299 4 NEW NEVER USED Chrome 45,000 Colt Coil $40.00 $35.00 5 NEW NEVER USED Pretronix Module (Sold with Distributor Only) $0.00 $0.00 11 OEM Center Console Plate (blasted & repainted) $239.00 $50.00 12 OEM Front Rotor Dust Guards L/R LIKE NEW (priced each) $40.00 $20.00 14 OEM Console Parking Brake Cover (pwr window, sml crack, repaired) $120.00 $50.00 15 OEM L/R Door Handles (priced ea) $55.00 $20.00 - SOLD 16 OEM Door Lock Trim Plates (priced ea) $34.00 $8.00 17 OEM Blower Motor (tested and working, blasted & repainted) $30.00 $15.00REDUCED! - $10 19 OEM High Beam Floor Switch $9.00 $3.00 20 OEM Hood Cable Boot (from firewall) $7.30 $3.00 21 OEM Parking Brake Bracket (blasted and painted) price ea $10.00 $5.00 22 OEM Air Pump Bracket Lower W/Bolt & Nut $71.00 $35.00 REDUCED! - $25 23 OEM Alternator Support Arm Upper $18.00 $10.00 REDUCED! - $5 24 OEM Dash Ball Retainer $15.00 25 OEM Driver Side Dash Air Vents Qty 2 priced ea $50.00 REDUCED! - $35 26 OEM Passenger Side Dash Air Vent (damaged flap, missing) $5.00 28 OEM Driver Side Kick Panel W/Curtsey Light (minor damage) $50.00 $15.00 REDUCED! - $5 - SOLD 29 OEM Rear Headliner Panels (some damage or cracks) $150.00 $25.00 REDUCED! - $15 30 OEM Clutch Pedal Return Spring (blasted & repainted) $7.00 $3.00 32 OEM Misc Vent & Heater Controls $20.00 33 OEM Door Shims Qty 4 (Priced ea) $5.00 $2.50 34 OEM Blower Relay (not tested) $11.00 $5.00 36 Brake Pad Pins New Qty 4 (Priced ea) $1.50 $0.50 37 OEM Rebuilt Speedo W/New Face Plate $299.00 $225.00 REDUCED! - $200 38 OEM Rebuilt Tach W/New Face Plate $134.00 $75.00 40 OEM Tie Rods L/R + Clamps & Bolts (not org bolts) Priced ea. $24.00 $15.00 41 OEM Master Cylinder (blasted & repainted) W/Cover Power Brakes $120.00 $75.00 42 OEM R/L Plastic Head Light Guards Sold as a Pair $37.00 $15.00 - SOLD 44 OEM Gas Tank Filler Neck $80.00 $20.00 46 OEM T-Top Belts (harware needs rechromed) $15.00 48 OEM Heater Coil $70.00 $35.00 REDUCED! - $20 51 Spinners (not sure of year) Sold ea $41.00 $20.00 52 OEM Front Exhaust Mount (blasted & repainted) $32.00 $15.00 53 OEM Windshield Corner Trim (needs plated) $100.00 $15.00 54 OEM Hood Release Cable (mounts to hood) $39.00 $15.00 55 Chrome Air Filter Cover and Element (Eldbrock) New $29.00 $15.00 57 Timing Chain, Fuel, Water Pump, Crank Seal Kit New $10.00 62 OEM Front Turn Signal Gaskets Pair $4.00 $2.00 63 OEM Coil Bracket (Blasted & Repainted) $22.00 $10.00 64 OEM Gas Filter Bracket $10.75 $5.00 74 OEM Cast Iron Original 350/350 (Intake Hot Dipped) Date Code E279 $200.00 $75.00 77 OEM Water Pump Pulley $99.00 $45.00 78 OEM Pistons 350/350 11:1 $100.00 $50.00 79 After Market Crank Pulley (OEM See Above If Desired) $52.00 $25.00 81 OEM Passenger Side Healight Cover (Crack, can be welded) $299.00 $100.00 82 OEM Ash Tray Cover (Blasted & Painted) $25.00 $5.00 86 OEM Valve Cover Vent Elbow $13.00 $5.00 88 OEM Wiper Solenoid Door Actuator (mounted behind tach) $80.00 $40.00REDUCED! - $25 89 OEM Ash Tray Housing (blasted & painted) $38.00 $10.00 REDUCED! - $5 91 OEM Rally Center Caps (GM Qty 4) Price ea $74.00 $45.00 - SOLD 94 1/2" Crager Offsets $40.00 $20.00 95 OEM Non T/T Horn Button W/Emblem $49.00 $20.00 - SOLD 96 OEM Wiper Control Switch $35.00 $10.00 97 OEM Blower Control Switch WO AC $29.00 $10.00 98 OEM Rag Joint Lower $15.00 99 After Market Temp Sensor New $2.50 100 OEM Vent Knobs Pair $12.00 $5.00 101 OEM Shifter Plate $18.00 $4.00 104 OEM L/R Vent Cables Price ea $22.50 $5.00 105 OEM Fiber Center Console Panel (Blasted & Painted) $30.00 $5.00 107 OEM 76-77 T-Tops GREAT CONDITION Latches, Headliners, hardware, trim and Gaskets in just about in perfect shape - Both for $299 108 OEM Brake Pedal to Master Cylinder Push Rod Clevis - $3.00 109 OEM Headlight Switch Knob & Rod - $5.00 110 OEM Door Latch Striker Pair - $9.00\ 111 OEM Alternator Bracket $30.00 - $15.00 112 - OEM Glass T-Tops and hardware. BOTH tops are cracked and would need either Acrylic or Glass. Frames are great shape and hardware as well. Cost about $500 (compare at $1200 for new)for a rebuild with Acrylic from Astro Tops. Glass could be more. But These places will also take this and give a $250 credit towards new ones... $175.00 PLEASE NOTE THE ITEM NUMBER WHEN ASKING OR PAYING FOR PARTS ON ALL CORRESPONDENCE. Thanks! |
Reduced prices of remaining items...
TTT |
Tell me if you still have items:
23, 33, 44, 91 and 111.
Also, did you keep the engine and trans? |
Have it all except for the caps those sold... Forgot to mark them, will do that now. Thanks for looking.
