install request - radar detector
anybody know how to connect a Cobra XRS-9345 Radar Detector radar detector to mirror on a '05 model..i have seen some pigtail connectors here but not for this radar...
Not sure exactly what your asking, you mean power coming from your radar detector needs to be hooked into the pink & black wire of your mirror connection?
Here's a link that might be helpful: http://www.bugmanweb.com/c6/escort.html Your power cord coming out of your radar detector should have two wires, a power & a ground. Just splice it into your mirror |
Originally Posted by MGretz70
(Post 1583429796)
Hmm that I can't help with, haven't seen one either. Is the power connection like these? http://www.buyradardetectors.com/Pro...cessories.aspx
If so just go to a radio shack and get you one and use that to splice into instead of using the original. |
(Post 1583430093)
If so just go to a radio shack and get you one and use that to splice into instead of using the original. yes it is...might just use their "hardwire" connection to the fuse box and be done with it...thanks |
Originally Posted by veloz
(Post 1583430297)
Just know it probably won't be 'switched' meaning you'll have to remember to unplug the sucker yourself, else you know what'll happen. Having a detector activate/deactivate with the ignition is, to me, one of life's pleasures. :cheers: |
Originally Posted by Landru
(Post 1583430494)
You can.
Just know it probably won't be 'switched' meaning you'll have to remember to unplug the sucker yourself, else you know what'll happen. Having a detector activate/deactivate with the ignition is, to me, one of life's pleasures. :cheers: Pat:cheers: |
Originally Posted by Pat Salerno
(Post 1583430543)
If you use the heated seat fuse , it will be switched with the ignition.
OP, choose the right fuse & you'll be good to go for a switched circuit. |
great pointers guys,,thanks...
