Originally Posted by Tullius
(Post 1583780507)
One thing about the curb weight versus dry weight is that it appears that curb weight seems to be based on more gas in the tank than in previous measurements for the C6. I read in a forum somewhere that that GM establishes the curb weight for a vehicle based on 2 gallons of gas in the tank. For the C7 I calculated:
With half a tank of gas I weighed it at 3,070. Gas weighs approx 6.5Lbs/Gal. Full tank = 18.2 * 6.5 = 118.3 Half tank = 118.3/2 = ~59 Curb weight minus half tank = 3118 - 59 = 3,059 Close enough. I'm 99.9% sure that GM's curb weights include a full tank of gas. |
Originally Posted by RC000E
(Post 1583781239)
We discussed this...basically the forging cancels its weight savings due to size, but you get a larger/stronger wheel for the same weight essentially. So, no real savings, but more or less bigger size and strength for free...
Wow everyone, talk about some really awesome findings. Had no idea Z51 wheels were the same weight as base wheels do to forged process! This really helps narrow the gap in weight from base to Z51.
When I take my car to the drag strip I always run on about 2 gallons of gas, so it's good to know what the car will weigh in racing conditions. AWESOME stuff! OK who has something else???? |
Originally Posted by SCM_Crash
(Post 1583783005)
I don't believe this is correct. GM stated the curb weight of my C5Z was 3,118.
With half a tank of gas I weighed it at 3,070. Gas weighs approx 6.5Lbs/Gal. Full tank = 18.2 * 6.5 = 118.3 Half tank = 118.3/2 = ~59 Curb weight minus half tank = 3118 - 59 = 3,059 Close enough. I'm 99.9% sure that GM's curb weights include a full tank of gas. http://m.motortrend.com/roadtests/coupes/1107_2012_chevrolet_corvette_z06_centenn ial_edition_test/ For all the criticism that GM has received here over the C7's weight, people don't take into consideration how government regulations has contributed to weight gain. There is virtually no consumer demand for AFM/cylinder deactivation for the C7 but it has to provide these features to help GM comply with CAFE standards. According to the presentation, AFM helped to contribute a 35.2 lb weight gain for the engine. The AFM exhaust valves contributed another 5.5 lbs. The transition from an aluminum torque tube to steel was largely due to vibration issues encountered when running in 4 cylinder mode. This added 15.4 lbs. and extra structural members to comply with Federal crash standards contributed another 18.5 lbs of weight. I think all together, regulatory compliance contributed to 51 lbs of added weight to the C7. |
What about the mag ride?...that would add some lbs to the Z51. I'm guessing it comes in at least 100lbs heavier than the base.
Originally Posted by rpanesar
(Post 1583784950)
That's a good question, if you did opt into Mag ride, how much more do the shocks weigh than the base shocks? I couldn't imaging it being that much more? |
I doubt mag ride adds a lot. I think they can even use less sway bar when the mag ride is selected, minimizing some of the gain.
One likely reason magazine test cars weigh more is because they are normaly loaded. The curb weights I have seen all use the 1LT base, and the additional weight figures for options is nowhere to be found.
(Post 1583784950)
Yeah, I wish I could order the Z51 without the larger wheels... Unless, I suppose, they are necessitated by the larger brakes.
If you add the weight of the larger forged wheels and the lower profile tires combined, the Z51 tire/wheel combo could be lighter than the standard. The tires are about the same outside diameter from what I have heard. So if the wheels are about the same, and the tires are lighter? I bet it's real close anyway.
Originally Posted by RocketGuy3
(Post 1583785805)
I doubt it. The brakes on my Z06 are larger (14" diameter) than the brakes on the Z51(13.6" diameter), and they fit inside the 18" front wheels used on the Z06. |
I REALLY hope this source is wrong.....
http://www.motorauthority.com/news/1...an-c6-corvette "The Z51 performance package will likely add about 150-200 pounds, according to GM Authority. Per the pricing released last week, the Z51 package will also add $2,800 to the price of the car." |
That seems a lot for the Z51.
Differential cooler 7 pounds Trans cooler slightly different location 1 pound E-Diff 15 pounds Larger wheels and tires 20 pounds Spoiler 10 pounds Dry Sump 30 pounds Rear anti-roll bar 20 pounds Total 103 pounds What did I miss? |
The EDiff should weight more than 15lbs but you are correct on all other things. Another thing to note, they are beefing up all of the suspension so it will have more mass
Originally Posted by Hemi Dave
(Post 1583779433)
Z51 wheels are forged
.......the non Z51 wheels are cast......so the bigger wheels may be lighter.
(Post 1583781239)
Not to say the C7 won't be different.. |
Originally Posted by JoesC5
(Post 1583785790)
On the C6 Z06, the mag ride is a 3 lb increase over the standard suspension.
I'll take the scales to the dealer. Anything under 3100lbs without fuel is awesome, under 3200lbs is great, under 3300lb and I'd still buy.
Originally Posted by TRAKCAR
(Post 1583795440)
3298lbs is with a full tank right? My first mod is getting non run flats, so that will shave some weight without a doubt :) |
(Post 1583785978)
