New 90MM NX Plate Kit W/ Gen X Kit
I still have the original NX box and almost all of the parts are still sealed in the packaging. I purchased the kit and Gen X accessory pack new in March. I removed the main line for test fitting purposes and mounted the plate for testing with my VaraRam intake. Other than that all the pieces are still vacuum sealed. My loss is your gain. I can provide pictures shortly.
What you get: Gen-X accessory package (heater, gauge, blow down, etc etc) 90MM Dry Plate kit (all you need is Fuel solenoid/lines for a wet kit) it is also set-up for a dual stage. 10lb bottle included (45 lightning valve) Shipped for everything: $675 Please contact me via text if you can: 503-400-ten77 Email: ShizzySupra@gmail.com |
Will also include a set of NGK 7 heat range and 8 heat range plugs, brand new still in the box from Summit.
