Looking for sponsors
I am planning on building a mile event car. I am planning on using the new stingray corvette. It will have a Nelson Racing Engine in it.
932ci 5.300" Bore twin 122mm turbos 125 Shot of nos (to assist in spooling of turbos) Lenco cs1 5 speed with reverse gear lever shifted trans ($10, 050) Suspension upgrades and roll cage will need to be done. Any help on finding a sponsor? How do I approach potential sponsors? Any advice. What companies would be a good starting point? I will be willing to drive to any event possible no matter how far away. |
Hell just send me a PM & I'm good for $50K that should be enough to get you on your way... :thumbs:
Good luck with the project... BTW Where are you .... you never filled out your profile... If you want I can run out Mon. morning and pick up the turbos...at least its a start...:cheers: |
Originally Posted by ROB's 2014 Vette
(Post 1583992364)
By the way, Transmissions. No trans would support this kind of power, so what should I do. Run with just a clutch? (like a top fuel dragster) Just mount the 932 side ways & run direct front wheel drive. You can thank me later |
(Post 1583992364)
By the way, Transmissions. No trans would support this kind of power, so what should I do. Run with just a clutch? (like a top fuel dragster) My Camaro made 721 HP from a 290 ci small block Chevy engine at 9600 rpm the car ran 8.03 @ 171 mph back in the 1990's Now D/A cars are running well into the 7 sec zone .... Also Pro Stock (yes a little less power) and Comp Eliminator car (I had a D/A Camaro) and we and the Pro Stock cars use LIBERTY TRANSMISSIONS ! |
Originally Posted by jpee
(Post 1583998843)
Wrong !!!... what do you think Pro Mods use or Alcohol Dragsters & Alcohol Funny Cars.... it called a LENCO TRANSMISSION
What happened with the drag racing team sponsorship and the 4000HP motor?
http://forums.corvetteforum.com/drag...cing-team.html |
Originally Posted by joe11204
(Post 1584011929)
(Post 1584016289)
I decided to do mile events instead. But even now I cant even start to think about the project. Just got some hefty vet bills.Having horses isn't cheap.
Originally Posted by Corvette Chris
(Post 1584021457)
Get rid of the horses and you'll free up a bunch of cash. :thumbs::willy:
(Post 1584021457)
