What the heck is going on??? Spare tire wheel well
I must be missing something but surely someone here has my answer:D
I got new tires and went with Diamond Back radials. So I picked up a standard spare tire the same size (205x75x15). Could not get it to fit in the spare tire well. So I went back and got a 205 x 70 thinking that would fit. You guessed it....nope. I guess it is the difference in tread width from the old bias ply tires. So what have others done for a spare???:eek: Thanks for any help |
Chevy S10 doughnut tire...T155/90 D16 :thumbs:
I have a 205/70 R15 Goodyear on a KO wheel. It fits with the longer wheel tub hangers. (the ones for a KO spare).
the newer tires are Streched out and the cover sticks up.
I put a tube in my spare and deflated it more so the cover would sit flush |
Originally Posted by burtonbl103
(Post 1584055957)
Originally Posted by Mike Terry
(Post 1584056103)
So let me get this straight. You deflated your spare tire so it would fit flush and now when you have a flat tire going down the road and go to put your spare tire on it to is deflated:crazy2:. There you go.
Originally Posted by capevettes
(Post 1584056268)
Hey Mike Bill is just used to those newfangled Corvettes with run flat tires :lol:
Originally Posted by 66jack
(Post 1584055886)
Mike |
Originally Posted by mcb55-210
(Post 1584057333)
Yep! Fits in my '62.
Mike |
Originally Posted by donbayers
(Post 1584055796)
Originally Posted by Subfixer
(Post 1584055924)
(Post 1584055957)
I put a tube in my spare and deflated it more so the cover would sit flush Don - you can try the longer bolts for the spare tire tub, that were used with goldlines or knock-offs (i forget which of those 2 requires the longest bolts). This creates more room in your tire tub. As for using a small spare tire, you can do that if you must, but if you have a flat in one of your rear tires, you'll need to put a front tire on the rear, and put the small spare on the front, so you don't risk damaging the clutches in your rear end. |
I had the same issue as Don last week so I used a 195/70-R15 for the spare. 205/70R15 on all corners using new 15X5 steel wheels.
(Post 1584057531)
OK, Are you saying this tire will fit on the original spare rim??
Spare tire
Have the same problem on my '67. Bought a can of fix a flat and pump powered by cigarette lighter. Hope I do not need them.
Originally Posted by drlparkway
(Post 1584060193)
I have carried the fix a flat can since it came out but that's probably pretty old now. |
Any shop you bring that tire to will hate you...at least give them a heads-up if you use the fix a flat. I have the same stuff in my car, but it's the backup to the backup. I'll give roadside assistance a call first.
(Post 1584056103)
Originally Posted by Godholio
(Post 1584060645)
rant over, ;) Russ |
