Rear Deck Vent Removal Question
I was curious as to how I would go about removing the vents behind the rear window. I recently had the car painted and the guy didn't take them apart to clean/paint the insides so it kind of looks funny. Thanks in advanced!
Edit: My car is a 75' w/ A/C |
They are held in place with trim screws. Remove the grills and you will have access to the area beneath them.
:thumbs: |
(Post 1584088293)
They are held in place with trim screws. Removed the grills and you will have access to the area beneath them.
:thumbs: |
Your 75 has a dummy vent opening. There is no opening in the body, just a grill sitting on top of the recess where the opening was on earlier models like Alan's.
Hi HBI,
Thanks I didn't know that! I got my 'eraser' out. Regards, Alan |
Originally Posted by Dboy23
(Post 1584088225)
My 75 AC coupe has the vent grills, SOLID fiberglass beneath that. NO opening and CANNOT see thru deck.
Originally Posted by Alan 71
(Post 1584090644)
Hi HBI,
Thanks I didn't know that! I got my 'eraser' out. Regards, Alan :cheers: |
Originally Posted by gkz
(Post 1584091653)
Mine is a '75 w/AC. Four screws hold each vent in, accessed from the top. I can see the gas tank shield beneath the vents--no plenum in mine. The recesses the vents fit into should be blacked out.
Originally Posted by mrmagrath
(Post 1584095163)
FYI, an eraser is called a rubber in New Zealand! Just in case you should ever date a Kiwi girl!
:cheers: |
Okay, what do they call a rubber in NZ? Lou.
Originally Posted by HBI
(Post 1584090055)
http://img.photobucket.com/albums/v1...ps84475f28.jpg |
Originally Posted by paul 74
(Post 1584142073)
Interesting. I can see the garage floor through mine (1974).
