High RPM Oil Pressure Drop
Well this just started happening.... first noticed on highway pressure would drop from 60 ->40psi only at full throttle above 4000rpm, off throttle at 4000rpm was fine....
Yesterday, gauge dropped right off (almost zero !) when pushing over 4500rpm in 1st, but returned to 60 after changing into second... super weird. Any ideas ? |
Keep it below 4k and you will be fine :D. Dumb question but is your oil level correct and reading full
(Post 1584173168)
Oil level is all good and even when pressure drops, no strange noises or otherwise.... I hope its the gauge, but its the stock mechanical one so probably not ! |
What oil weight you running and how old is it
(Post 1584173218)
Oil running away from the pickup under hard acceleration.
Originally Posted by claysmoker
(Post 1584173315)
How about a clogged pickup and cavitation in the pump?
Originally Posted by daz_au
(Post 1584173416)
Would certainly fit the symptoms... but why all of a sudden ? If the pickup fell off, would I get any oil pressure at all ?
Try slowly getting up to speed and dropping back a gear to make the engine rpm come up without acceleration involved. If the pressure stays up I'd say the oil is running away from the pickup. I had a setup in one of my engines that would drop pressure under hard acceleration. I had to build some baffles in the pan to keep the oil around the pickup. |
(Post 1584173764)
Some of the pickups aren't too far below the hole in the oil pump and you would still get oil when sitting still or accelerating slowly. It could also be a cracked pick up tube
Try slowly getting up to speed and dropping back a gear to make the engine rpm come up without acceleration involved. If the pressure stays up I'd say the oil is running away from the pickup. the cracked pickup tube sounds plausible. However, under hard acceleration, the oil is going to "pile up" at the rear of the pan where the oil pump is, and (I'm just guessing here ) you probably wouldn't even need a pickup tube to get oil into the pump. Bad filter, or somehow bypassing back to the pan??? :cheers: Gerry |
Drain the oil and put a scope in through the hole and see if the pick-up is still on the pump .
A fair bit of oil will be suspended in the top end as the RPM's rapidly increase . Bill |
Originally Posted by Mossy66
(Post 1584173976)
I like this. Nice simple trouble shooting method.
Originally Posted by 63split63
(Post 1584174053)
(Post 1584174061)
The oil really doesn't just "pile up" at the back of the pan. I goes right up the back of the pan, around the rear main cap and keeps going into the rear counterweight on the crank. No matter, it gets away from the pump, pickup and the place you need to trap it in any case.:lol:
In your scenario, the crack in the pickup tube would be a bit lower than the static oil level in the pan, but at hard acceleration, the oil level at the pickup tube drops to a point where a crack would be sucking air. I guess that means that if in your earlier troubleshooting method the OP retains oil pressure, it's time to drop the pan and look at the pickup. :cheers: Gerry |
Here is my 2 cents:::
Put in a temporary gauge where it comes out of the block... Start it up and see if it fluctuates when going through the RPM'S...:leaving: That way you can eliminate a faulty gauge and go from there.... |
(Post 1584174277)
Inspection camera is a good idea, dont have one but have been looking for an excuse to get one :) Pulling the pan (and replacing/sealing it) from under the car doesn't seem like fun.... |
Try this
Run some rislone cleaner in the oil you have in it and drive it around easy for a bit. Something is plugged (something loosened and is blocking something. It may be your drain back holes. Since you have pressure to 4000rpm at 40 and this is only happening at rpms, the oil is trapped in the upper part of the engine at rpms. I also did not like that you said your gauge completely hit zero. If accurate that is a big problem. Thus first clean/tighten the connections on that gauge!
If your engine builder plugged the filter bypass valve and your oil filter is stopped up, you will have a pressure drop like you describe.
Add an extra Quart of oil and run the car up to problem zone. If this fixes the problem drop the Pan and do a visual inspection. Al W. (Back in the day we always ran an extra Quart of Oil because these cars leaked so much! lol).
Appreciate all the feedback... I will drop the oil and filter this weekend, see if I can get an inspection camera into the pan and hopefully find a cause that makes sense.
It still has the old canister oil filter which I changed about 6mths ago (wix), I was thinking of getting one of the conversion plates to run a modern filter... not sure if that is recommended. I did learn something with all the focus on my oil pan today, looks like I still have the stock L76 6qt pan on there based on some photos I found here on the forum of 5qt vs 6qt pans ! It is also leaking front and back surprise surprise..... |
