WTB c4 corvette parts--list enclosed
ok first the basics.. the parts in list need to fit or interchange onto 1985 tpi corvette and my location is iowa, i am open to local items as well as shipping but just wanted to make aware of location. and now on with the list of needed parts, please respond here or pm or email if you have any of these items avalible for sale .. thanks
#001 fuel tanks sending unit assembly (with or without working fuel pump) #002 fuel filler area rubber boot #003 drivers side rear inner fender well (wheelhouse) #004 front lower fender well drivers side(front wheel and aheav of wheel) #005 hatch switch/button (drivers side mounts in rear of door panel) #006 aluminum water neck (thermostat housing) as the one i have is cast iron and cant be polished #007 door (just the shell needed) passengers side..just in case someone is local or can get good ship rate #008 is it true that the 94-96 corvettes used glass underhood light lenses that will fit on the 85 corvettes? if so i may be interested in a pair of those as well |
#002 fuel filler area rubber boot #003 drivers side rear inner fender well (wheelhouse) #004 front lower fender well drivers side(front wheel and aheav of wheel) #005 hatch switch/button (drivers side mounts in rear of door panel) #006 aluminum water neck (thermostat housing) as the one i have is cast iron and cant be polished #007 door (just the shell needed) passengers side..just in case someone is local or can get good ship rate #008 is it true that the 94-96 corvettes used glass underhood light lenses that will fit on the 85 corvettes? if so i may be interested in a pair of those as well Have everything you need . will beat any lowball offer on here, one stop shopping right here!! Please send me an email and I will gladly help you out Shawn@corvettenutz.com |
ttt
email sent .. let me know those prices i just cant say no to :thumbs:
untill then still looking for the above items thanks |
I have a complete under hood light setup and the rear hatch switch,these parts are new G.M. never touched a car.$30 for the switch and $175 for the lights.
inner fender plastic
I have a set for your car 84 to 90 inner fender rear $50 for the pair I'm near bloomington il we can meet up and get them to you if you like sometime:rock:
I have the fuel sending unit assy out of a 1994... don't know if it will work in an 85. Let me know if you're interested and I'll post pics of what I have.
