Installing Quartermaster Vdrive 5.5 need torque specs
Just about to bolt up my quartermaster V Drive 5.5" clutch and realized I don't have any torque specs. Need specs on the ARP bolts that go through the clutch mounting plate, though the flywheel, and into the crank snout. Also need specs on the long bolts that go through the clutch body to hold it all together.
Any help is appreciated, Thanks |
Flywheel is 3 passes.
15, 37, 74 ft/lbs The bolts that hold the clutch I couldn't find a torque spec when I put mine together so I just did about 30 ft/lbs and I used nord-locks. Last time I had it apart after about 8 weekends of running all was good. |
Where did you get the 74 ft/lb number? I looked it up and found a few references for arp flywheel bolts at 55 ft/lbs. Btw, clutch body is 20 ft/lbs as per qm's website. I torqued mine to 55 wonder if I should pull it apart...
Originally Posted by moespeeds
(Post 1584458912)
