Heads and cam build results
My build initially was planned to just be a ported/milled heads, ported stock intake and a cam. It quickly ballooned a little beyond that lol. Anyways here is the mods list:
Ported and milled Brodix heads with del west Ti intake and Ferrea hollow stem exhaust 12.5:1 compression Manley Nextek valve springs and bronze guides Ported FAST 102 and NW 102 24x/25x .6xx/.6xx 111+2 cam ID850 injectors Comp trunion upgrade Morel 5206 Link Bar lifters TSP chromoly 7.725" pushrods E85 fuel I'm sorry to say I don't have dyno numbers but I am very pleased with how this car runs. It makes torque everywhere and pulls extremely hard above 4k. I did this build looking for as much power as possible on a street able setup. However, I do have track times! Here are the time slips below I believe indy had about a 2500ft DA last night. All of the runs were on street tires and a stock clutch(which sucks btw). http://i857.photobucket.com/albums/a...6/image-15.jpg |
I should also add this is the first time out in this car or any Z06 for that matter. Thus the reason for the 2.1 60 ft times lol
Should have alot left in it. I would think that's. 140mph combo.
Who tuned it? "seems" like it should be a bit faster for what it has...
A guy I know tuned it. It wasn't tuned by a shop, he is a well respected tuner in the Lafayette/Indy area. The car does need a 160 degree thermostat, my tuner said we should be able to get a couple of degrees of timing in it with one. However, the biggest reason it isn't as fast as one would expect is the absolutely terrible traction, I was spinning into 3rd. Also, I need to work on my driver mod a little lol. It isn't easy to add a bunch of power to a car and go run 9.90's at ~140 like a car "should"
Congrats on having traction problems with the new power, I am sure it is a whole new animal! Curious what tires you were on?
General exclaim UHP, they are the tires that were on it when I bought it used.
Originally Posted by DaytonaFIC6
(Post 1584508367)
IMO You should be easily in the 10's
My head and cam Z06 ran low 10's in San Antonio hot weather |
What tires were you on? What was your 60ft?
