Placement of Jack Stands
Need help from the forum. I have a 2013 GS and need to install a Billy Boat exhaust. Where do I need to place the jack stands? I have never been under the car until now. All help is greatly appreciated.
I used two under the engine cradle and 1 on each rear side rail. you need to get @ 18" up in the air.
Thanks for the link. Never thought i would need a new jack.
Since I didn't have funds for a lift right now, I invested in some cross beam adapters from Smith Fabrication (no financial interest, just a satisfied customer) that work well- jack, place stands underneath, remove jack:
http://billswebspace.com/corvette184.jpg http://billswebspace.com/corvette188.jpg |
Smith Fabrication Cross Beam Adapters
Tell me more about these cross beam adapters! Where to buy them? What do they cost? I am interested--these are the solution to the Corvette jacking problems!
Web site? |
Thank You VERY MUCH! You can bet I'm going to order some today!!
Summit Racing also carries a Cross Beam Adapters for $45 and $105 http://www.summitracing.com/parts/sum-918008 |
Originally Posted by Forvettes
(Post 1584540342)
WOW - $250. I guess that Corvette logo adds a lot to the price.
Summit Racing also carries a Cross Beam Adapters for $45 and $105 http://www.summitracing.com/parts/sum-918008 Some were even lucky enough to get these same cheaper universal cross brace adapters when Northern Tool closed them out at ~$10 a few years ago. Lots of options out there if the gauge of steel used and manufacturing satisfies you and you don't mind modding them- lots of forum members are using these without any issues. I chose to go with Jim's, and actually took the measurements and pictures to help Jim develop them for the C6. They use better/thicker gauge steel, are ready to go as soon as you open the box, and are built for a C6 Corvette- not universal. My time is valuable/limited and I like the materials used a bit better so it was worth it to me. The stickers were free and a US small business/fellow Corvette owner is supported :D I was looking for something better and happened to see a picture Jim posted with these for his C5 and inquired about him building some for a C6. Not for everybody but they are beefy and well built if that is what you are looking for. |
(Post 1584540342)
Originally Posted by wrh3
(Post 1584535119)
Originally Posted by mastergunner
(Post 1584540860)
So I noticed you do not have a super long reach on your jack. How do you get the front end up?
All kinds of option if you think about it. This is my take with 304 cres box tubing and T6 jacking pads, adjustable for both front or rear cross member:
http://i896.photobucket.com/albums/a...6/P1010157.jpg Foreground shows the prototype using "U" channel and the back one is the final version with milled T6 adjustable jacking pads: http://i896.photobucket.com/albums/a...P1010153-1.jpg The drive up ramps up front are no longer used. Now after jacking up at behind front wheel shipping slot (Jacking puck slot) I use these, first one side then the other. Which offers three different heights as well as at under tire contact patch or frame rail, all depending on work demands: http://i896.photobucket.com/albums/a...ps327a3640.jpg I am not in business or promoting others business. Just ideas to share. :thumbs: |
Originally Posted by victorf
(Post 1584541796)
Nice work, guys! Glad to see some more C6 cross beam adapter progress happening. :thumbs:
Hey, I believe I started the C6 cross beam craze back in Febuary of `06 with the below linked post. Was an original idea I had after refusing to lift the car from any spot not designated by the Corvette owner's manual: http://forums.corvetteforum.com/c6-c...g-c6-pics.html Got put down quite a bit by guys claiming to regularly lift the C6 from spots not designated by the manual and also by guys trusting 2"X6" pieces of wood as cross beams etc. When I work on cars, I don't like to take risks just to save a few bucks. A crushed limb or a damaged aluminum structural member is gonna cost a whole lot more than a few good cross beams. I still feel that the steel cross beam adapter idea is best for DIY lifting and supporting of the C6 when you do not have a proper lift available. Has worked fine for me for the past 6+ years, safe and proper. I like the new cross beams in this thread... very cool!!! Some nice improvements over the old Harbor Freight ones. I approve!!! :D :thumbs::thumbs::thumbs: |
