C1 Electrical Wiring Issues
Recently installed new wiring in my 1958. Everything works fine except the interior light and heater motor. Any suggestions for how to go about finding a remedy? Thanks.
check the grounds and check the connections. You might need to clean the connections off. I would check to see you are gettiing power the end of the wires. The interior light works off of the headlight switch check to make sure it is connected. Did these items work before with the old wire harness? Fuse?
Originally Posted by blackvette58
(Post 1584540747)
