Mirror lights staying on
Has this happened to anyone and what might it be??
2 times now i have had to disconnect my battery to get to mirror lights to go out. I notice my radio and gauge lights get dull or bright from time to time also. any IDEA'S ???? |
The owner's manual says they will go out after about 20 minutes, which has been true for me, if they are left in the "on" position. I inadvertently leave the driver's side light on all the time.
When you turn the car on, make sure both lights are off. If they are off while the car is running they should shut off after you exit the car. They are controlled by the pushbutton next to the light, and also by the dashboard light control to the left of the steering wheel. They should go on when you exit just like the dome light they are replacing, then go out. The dashboard light control switch might be getting pushed in or turned, and that may be what is affecting the other light too. Check the owners manual for how that control works. |
Thanks i also just read some old threads on it. It seems many have bumped the switch on the dash and i can understand, But I drove 40 miles trying the button on the dash and it just didnt want to go out I had to diconnect the batt. wait a few and reconnect.
Originally Posted by tjm9746
(Post 1584555580)
The mirror lights won't go out as soon as you press that dash dimmer switch. It will just cause the mirror lights to go out normally after you get out of the car, close the door, and optionally lock the door or auto lock the door. |
