F/S Parting out 1974 Corvette Stingray Coupe
After three years of tear down, I've decided to part this out. I have over $25,000 in parts. Just looking to make some of the money back and it would be nice to have the space back. I'm still in the middle of separating the fiberglass panels. The body is off the frame at this point.
Shoot me an offer on the part you want. I don't have the stock gauges. I do not have the front headlights, I was in the middle of switching over to a fixed light system. Call or Text Chris @816-723-6138 Here's a video of the engine running. https://post.craigslist.org/imagepre...xi_600x450.jpg https://post.craigslist.org/imagepre...5k_600x450.jpg https://post.craigslist.org/imagepre...G2_600x450.jpg https://post.craigslist.org/imagepre...C2_600x450.jpg https://post.craigslist.org/imagepre...mz_600x450.jpg https://post.craigslist.org/imagepre...Tm_600x450.jpg https://post.craigslist.org/imagepre...P2_600x450.jpg LH Rear Fenders 250 RH Rear Fenders 250 LH Front Fender 215 RH Font Fender 215 Hood - L88 Custom Scoup 300 Rear Deck 500 Z06 Mirrors 300 LH Door - This is one of the best examples you will find. No rust no hold they are almost perfect. 349 RH Door - This is one of the best examples you will find. No rust no hold they are almost perfect. 349 Corvette Drivers Side LH Window Crank Regulator Shaft Housing 1968-1980 (Fits: Corvette) 25 Corvette Drivers Side RH Window Crank Regulator Shaft Housing 1968-1980 (Fits: Corvette) 25 Corvette Coupe Rear Window Glass w/o Defroster Dated NI 1973-1977 169 Corvette Original LH Drivers Side Door Window Glass IC 1975-1982 (Fits: Corvette) 124 Corvette Original RH Drivers Side Door Window Glass IC 1975-1982 (Fits: Corvette) 124 Corvette Original RH Passengers Side Window Track Set Late 1969-1982 (Fits: Corvette) 36 Corvette Original LH Passengers Side Window Track Set Late 1969-1982 (Fits: Corvette) 36 RH Corvette window motor access cover. 25 LH Corvette window motor access cover. 25 1968-1975 Corvette Rear Vents Grille Rat Rod C3 Deck 454 350 LT1 427 Window Hood 35 Corvette Original Black Fiberglass Rear Storage Area Wheel Well Tub 575 Corvette BirdCage 600 Corvette Firewall 400 C3 Corvette 1968-82 LH Window Regulator 150 C3 Corvette 1968-82 RH Window Regulator 150 Corvette Original Windshield Header Moulding LH & RH Pair 1969-1976 (Fits: Corvette) 69 1973 1974 Corvette Vette C3 Front Windshield Molding Trim Set USED GM 3pcs 125 69-74 CORVETTE WINDSHIELD WIPER MOTOR OEM GM C3 (Fits: Corvette) 50 Corvette Original Windshield Header Moulding Molding Trim Silver 1969-1976 (Fits: Corvette) 66 Corvette Original Windshield Washer Wiper Fluid Reservoir w/Neck 50 1976L - 1982 Corvette C3 Windshield Mount Inside Rearview Mirror Day-Night (Fits: Corvette) 40 Corvette Windshield washer pump 50 1969-1974; C3; Windshield Wiper Arm; LH Driver 50 1969-1974; C3; Windshield Wiper Arm; RH Driver 50 Used 74 C3 Corvette Windshield Wiper Motor sms (Fits: Corvette) 75 Corvette C3 Complete Windshield Wiper Transmission Setup 150 C3 Corvette 1972-76 Windshield Wiper Switch Plate w/Air 125 Corvette Windshield Glass 1973-1976 Front Window 2 Door Coupe 330 Corvette Original Manual Crank Window Regulator Bezel Pair Dark Saddle 1968-1977 (Fits: Stingray Corvette) 25 1975 1976 Corvette C3 cross flag Cloisonne FUEL gas door EMBLEM,vintage original 50 1968 - 1977 Corvette C3 Inside Door Lock Knob Set with Clips 17 Corvette Outside Door Handles, Pair Right and Left door 65 1969L-1982 Corvette Door Hinge car set Rebuilt C3 150 Corvette Passenger Side RH Door Lock Jam Pillar Panel 100 Corvette Passenger Side LH Door Lock Jam Pillar Panel 75 C3 CORVETTE NEW DOOR LOCK STRIKER 12 69-77 CORVETTE LH SIDE DOOR LOCK LATCH STRIKER ASSEMBLY 75 69-77 CORVETTE RH SIDE DOOR LOCK LATCH STRIKER ASSEMBLY 75 Corvette Original Passengers Side RH Door Latch Handle 50 Corvette Original Passengers Side LH Door Latch Handle 50 Corvette OEM Fuel Door Gas Lid Bezel & Hinge Chrome 1971-1977 (Fits: Corvette) 50 Corvette Original Fuel Door Gas Lid 35 74 Corvette Original Fuel Door Gas Lid 35 Corvette Original Rear Bumper Cover 275 Corvette C3 Steering Column 500 Corvette NEW Steering Column Shaft Rag Joint Flex Coupler 1969-1982 (Fits: Corvette) 53 Corvette Early Steering Column Rag Joint Coupler Upper Flange 1968-1982 37 Bumper Reinforcement 199.97 Outter Bracket for Brace 154.97 Bumper Guard 69.97 Outer Extension Bracket Rod 27.99 Front Bumper Bar Extension Bracket 13.97 1968-1982 C3 CORVETTE HOOD RELEASE CABLE WITH HANDLE 25 C3 Corvette Windshield Wiper Switch 10 C3 Corvette Heater Blower Switch 10 64-87 GM Door Strikers Camaro Chevelle Corvette Nova Impala 15 Corvette Door Pillar Water Diverter, RH, New 12 Corvette Door Pillar Water Diverter, LH, New 12 C3 Corvette Inside Door Release Handle 45 Corvette Rear Storage Compartment Middle New 40 Corvette Rear Storage Compartment Left New 45 Corvette 74 75 76 Rearview Mirror Day Night 45 68 69 70 71 72 73 74 75 76 Corvette Automatic Shifter 70 1974 Corvette Gas Pedal,Cable & Wide Open Throttle Switch 55 Corvette Dimmer Switch Pedal C3 17 1968 to 1982 Corvette brake pedal assembly 59 1969 L-1976; C3; Accelerator Pedal Lever Supprt Rod Brkt 45 Corvette Original Floor Heater Outlet & Duct Assembly with A/C 1969 209 Corvette Original RH Fender Fresh Air Plenum Flapper 1969-1982 84 Corvette Original RH Passengers Side Air Outlet Duct w/AC A/C 1969-1976 74 1968-1981 Corvette NOS 1996607 AC Vacuum Actuator on Plenum 69 70 71 72 73 74-81 125 74 75 76 77 CORVETTE DRIVER SIDE AIR DUCT 74 Corvette Original Car Heater Footwell Outlet Air Diverter Duct 1970-1976 69 Heater Door Vent Cable w Adjuster & Bracket ORIGINAL for 1968-1976 Corvette 30 1968-1982 (From 1974) C3 Chevy Corvette interior under dash heater box with A/C 94 68-77 Corvette Heat Center Gauge Cluster Duct 49 ACDELCO OE SERVICE 15-885 Relay, Blower Motor-Blower Motor Relay 25 72 73 74 75 CORVETTE TEMPERATURE CONTROL UNIT 150 1974 corvette air conditioning underhood box 1969 -1976 HARRISON 300 Corvette Original Center Gauge Cluster Bezel Frame w/ A/C 1969-1974 85 Corvette 73-76 Early NEW Radiator Core Support 74 75 1973 1974 1975 1976 293 3 Row 1973-1976 Chevy Corvette Champion Aluminum Radiator + Two 12" Fans (Fits: Chevrolet Corvette) + Fan Temp Control 300 Corvette Original Engine Coolant Recovery Radiator Overflow Tank 1974-E1977 (Fits: Chevrolet Corvette) 65 Corvette Original Engine Coolant Recovery Radiator Overflow Tank 1974-E1977 (Fits: Chevrolet Corvette) 35 GM Performance 12497697 Pulley Kit Serpentine Steel Black Chevy Small Block Kit 695 Tuned Port Injection Custom with Big Injectors, Custom Wiring and CPU for Resto Applications 750 GM Performance Crate Motor 4 bolt main - Has a Mild Cam 1900 TH400 300 Converter 100 Frame 1500 Corvette Original Differential 500 Brakes new vented and slotted with ceramic pads 300 Half Shafts 100 Drive Shaft 100 Trailing Arms 350 Rear Hub LH 100 Rear Hub RH 100 Front Hub LH 100 Front Hub RH 100 Exhaust Custom setup up for early C3 with Z06 Tips and New FlowMaster 40s Header Accumalator back 250 Gas Tank 400 A-Arms 800 Corvette steel automatic transmission cross member TH400 275 Corvette Original Rear End Differential Mounting Crossmember 275 Pitman Arm 69 Power Steering Hose Set 47 Power Steering Gear Box 58 Power Steering Slave Cylinder 70 Steering Coupling/Coupler Rag/Flex Joint NEW 55 LH Steering Knuckle Arm One Hole 45 Idler Arm-Steering Idler Arm 20 Power Steering Center Drag Link 74 Tie Rod Adjusting Sleeves 35 Tie Rod-Steering Tie Rod End 70 C5 Wagon Wheels 350 Wheel Spacers 200 68/76 corvette power brake booster with Master Cylinder 75 Corvette Original Brake Line Metering Proportioning Valve Block 50 Brake Lines 50 Corvette Original Brake Calipers 200 Corvette Original Disc Brake Caliper Splash Dust Shields Replated 1965-1974 150 Corvette Original Brake Caliper Brackets 1965-1982 160 Corvette Front Bumper Lower Valance Panel Air Dam Fiberglass 1973-1979 75 1973-1979; C3; Front Spoiler; NEW; Corvette 49.99 Z06 Seats 800 Corvette Original Coupe Rear Window Plastic Frame Saddle 1973-1977 (Fits: Corvette) 60 Corvette Original Rear Back Window Interior Lower Trim Black 1968-1972 (Fits: Corvette) 124 1969-1977; C3; Center Console w/o Power Window Cutout 60 Corvette OEM Passengers Side RH Windshield Pillar Post Trim 60 Corvette OEM Passengers Side LH Windshield Pillar Post Trim 60 CORVETTE C3 DOOR SILLS -- USED GOOD CONDITION 45 Corvette C3 RH Door Panel 150 Corvette C3 RH Door Panel 150 C3 Corvette Door Pull Handle 15 Corvette OEM Door Handle Latch Rods and Pins 1969-1982 (Fits: Corvette) 26 Corvette OEM Door Handle Latch Rods and Pins 1969-1982 (Fits: Corvette) 26 1968 thru 1977 C3 Corvette LH Inside Door Handle Opening Control 50 1968 thru 1977 C3 Corvette RH Inside Door Handle Opening Control 50 68 69 70 71 72 73 74 75 76 77 C3 CORVETTE PAIR INSIDE DOOR HANDLE BEZEL 50 Corvette Original Rocker Panel Molding Pair 150 Corvette Lower Steering Column Cover Nice Original Stingray 25 Corvette C3 Vinyl Sun Visors 49.99 70 71 72 73 74 75 76 77 CORVETTE DASH PAD UPPER 200 Corvette Original Passengers Side RH Lower Dash Pad with Map Pocket 1971-1976 200 1968 to 1977 Corvette lower dash panels 100 Corvette OEM Passengers Side RH Rear Halo Roof Panel Saddle 1974-1977 39.99 Corvette OEM Passengers Side LH Rear Halo Roof Panel Saddle 1974-1977 39.99 68-76 Corvette T-Top Center Panel Trim Moulding 39.99 Corvette Original Rear Defroster Setup 1974-E1976 Coupe 300 1974 Corvette C3 Tail Lights w/ Backup Lights (4 Pieces) GM Restoration (Fits: Corvette) 174 Corvette Original Drivers Side LH Front Amber Marker Lamp 1973-1974 (Fits: Corvette) 64 74 75 76 77 78 79 80 81 82 C3 CORVETTE REAR MARKER LAMP NEW GM PAIR LEFT & RIGHT 110 |
Originally Posted by Ibanez540r
(Post 1584670875)
I'm still going through the list trying to locate the parts and prices, LOL, but I'm interested in the Autometer gauges and the dash pad so far..
https://post.craigslist.org/imagepre...Uw_600x450.jpg https://post.craigslist.org/imagepre...lr_600x450.jpg https://post.craigslist.org/imagepre...Vp_600x450.jpg |
Same here about the list, but I am interested in about anything that will fit the interior of my 77. Dash pad, etc. The door panels won't work as I have PW and the console parts are different, but a lot of other stuff will. Can you PM me a price for the rest of it if it will fit mine? I would appreciate it!
Originally Posted by CaseyJones
(Post 1584670976)
Corvette Original Coupe Rear Window Plastic Frame Saddle 1973-1977 (Fits: Corvette) Corvette OEM Passengers Side RH Windshield Pillar Post Trim Corvette OEM Passengers Side LH Windshield Pillar Post Trim CORVETTE C3 DOOR SILLS -- USED GOOD CONDITION C3 Corvette Door Pull Handle Corvette Original Rocker Panel Molding Pair Corvette Lower Steering Column Cover Nice Original Stingray Corvette C3 Vinyl Sun Visors 70 71 72 73 74 75 76 77 CORVETTE DASH PAD UPPER Corvette Original Passengers Side RH Lower Dash Pad with Map Pocket 1971-1976 1968 to 1977 Corvette lower dash panels Corvette OEM Passengers Side RH Rear Halo Roof Panel Saddle 1974-1977 Corvette OEM Passengers Side LH Rear Halo Roof Panel Saddle 1974-1977 |
Man if you were closer to Arizona I would consider that motor. Might be interested in the speedo, tach and dash if it is not spoken for yet.
Originally Posted by 91turbo2
(Post 1584679509)
Possible interest in brake lines, brake booster w/master cylinder. What kind of condition are they in and how old? Thanks
Do you still have the head light support brackets? I need the drivers side.
(passenger side example) http://i.ebayimg.com/t/CORVETTE-HEAD...F9w~~60_35.JPG |
how much for the dash astrovent ball assembly's? I dont need the balls them selves just the valve assembly they reside in.
Originally Posted by vette427-sbc
(Post 1584682957)
Originally Posted by NECorvette1976
(Post 1584682740)
where in Mo. are tou located???
Mike |
In Lee's Summit, MO 64081
How much for the full exhaust including headers? shipping to 32780
What size and type are the wheel spacers? And what about the steering wheel and installation kit
How much for the dash harness? What condition is it in? Has it been cut up?
By the time the exhaust was cut up for shipping, you could have someone else create a custom one for less. The shop that did mine used one piece of pipe.
75 shipped. It has been modified. I'll post pictures once it's off the car.
The wheel spacers are 2.5 and 3 inch. They are made of CNC Machined 6061 Billet Aluminum & Grade 8 Hardware. I would take 125 for both shipped. They have about 6 miles on them which is the moving in and out of the garage and up to the exhaust shop.
