C5 Halo LED Tails @ JWM- SHIPS FREE! *UPDATE YOUR REAR TODAY*
Update the look of your C5 with our led tails. These are brighter and just look better than the OEM sets. See below for more options http://i162.photobucket.com/albums/t.../HALOTails.jpg http://i162.photobucket.com/albums/t...halotails2.jpg http://i162.photobucket.com/albums/t...Halotails3.jpg These LED lights come with everything you need to install. Simply unscrew your old lights and install these. Everything is plug n play. These LED Halo tails are brighter than stock lights which increases visibility and safety. This includes 4 tail lights for a complete set. 28 high powered leds plus the halo rings $255 shipped for non modifed sets ** STANDARD Non modded sets function just like the stock lights only brighter. When you brake the lights get brighter to let others know you're slowing down. The halo ring around the outside along with the inside leds are lit when the lights are on. Standard Halo Mod OPTION** Add $35 to your order for this mod I personally think this is a safer lighting arrangement as there is an intensity change in the original/stock halo rather than the separation of lights, like in the mod. No question really if you're on the brakes when the light has been modded. When your lights or fogs are on the halo around the outside is the only part of the light that comes on. When you brake or use your turn signal the inside leds (28 of them) comes on to let others know. If you are braking without the lights or fogs on only the inside portion (28 leds) lights up. Trust me they're bright! With this mod the halo portion you see in the above pic is lit. When you press the brakes the whole light comes alive like the pic below. This mod takes us approx 5-7 business days. LED Halo OPTION ** This mod replaces the halo ring around the outside of each tail with our flex led strips.This mod actually adds a little brightness to the already super bright halos. This option is perfect for those that run tinted lenses. Add $123 for this. They still function the same. This mod takes additional time to complete. Expect 10-18 days. New LED Halo on the left and the normal halo on the right http://i162.photobucket.com/albums/t...DHalos2014.jpg WARRANTY See full warranty info on our site |
FAQ 1. Will these tail lights cause hyperflashing? Sometimes with modded sets they hyperflash. Some need it most don't. I usually suggest trying them out before buying the hyperflash harness. It's not common. 2. Will they work with sequential flashers? They work great with the halos
Originally Posted by clif
(Post 1577557913)
Yes, I have the sequential mod with my LED tinted lights:
Please see post 1 under each option. |
