New build. 5.3 rear mount c5z06
Motor:
5.3 L33 stock bottom end LS6 cam 799 heads ls1 intake/tb ls9 head gaskets arp headstuds ls7 lifters dual gold springs Turbo: precision billet 7175 .81 ar treadstone 1300hp vette style intercooler tail wastegate tail bov aem wideband boost gauge 2.5 bar map MM boost catch can aem meth kit/klotz race fuel concentrate/92oct 3inch stainless hot side wrapped 3in cold side aluminum. Vibrant VanJen v band Clamps c5z exhaust manifolds Upp fuel kit 80lb injectors turbowerx exa return pump. drivetrain will be stock m12/ stock 3.15 3 rib for right now. street use only. Motor goes in this week, fabbing starts right after. https://cimg9.ibsrv.net/gimg/www.cor...dbe309f525.jpg https://cimg0.ibsrv.net/gimg/www.cor...32c6d17df3.jpg https://cimg1.ibsrv.net/gimg/www.cor...ea71359c5e.jpg https://cimg2.ibsrv.net/gimg/www.cor...98bf45e23f.jpg https://cimg3.ibsrv.net/gimg/www.cor...a1204a9e0c.jpg https://cimg4.ibsrv.net/gimg/www.cor...5119513f07.jpg https://cimg5.ibsrv.net/gimg/www.cor...04fa7b33f7.jpg https://cimg6.ibsrv.net/gimg/www.cor...b587b7de56.jpg https://cimg7.ibsrv.net/gimg/www.cor...fff6bd2585.jpg https://cimg8.ibsrv.net/gimg/www.cor...9465ea7c77.jpg https://cimg0.ibsrv.net/gimg/www.cor...0c4235cebf.jpg https://cimg9.ibsrv.net/gimg/www.cor...2d61ce05ca.jpg https://cimg1.ibsrv.net/gimg/www.cor...51a342c847.jpg |
this sounds awesome! :lurk:
Cool build.......how many lbs of air is that wheel rated at ??
i dont know the rating on this turbo. i know its done over 1k whp on a 3.4 stroker supra. looking to be in the 700whp range think its got enough air for that. trying to spool as fast as possible and not choke up top.
Sounds like its going to be a real monster!!
so you swapped to auto gears in your 3-rib? that should help initial spooling
We decided we are going to go with a divided housing with a .96 ar. We are also going to run a quick spool valve. Might as well get the most out of it. Car is on the rack and underway. Will be posting pics as we go.
And it begins!
https://scontent-a-sea.xx.fbcdn.net/...33349148_n.jpg |
Originally Posted by DANZGLASS
(Post 1584882580)
Subscribed... |
turns out they dont make a divided housing for this turbo so the quick spool valve is out for now. We are sticking with the .81 unless it stops us from making 650+
If 650 is all you're shooting for then you MAY be fine. It may just hurt it some up top!
hoping for 700whp actually. But i can swap if it needs a bit more to get there.
Good deal. Gonna be a blast regardless.
why are you using a 5.3 if you want 700hp the stock ls1 or ls6 will work unless you toasted your stock ls1 already?
Originally Posted by a/c man
(Post 1584978873)
Pretty sure the shop I was using did ****** valves REV probably. Which failed in no time.
(Post 1584980233)
I had a 403 with a 150 shot actually. Made 535 NA. Had a ls7 small bore top end. 6 k on that motor and two hits of the nitrous. Intake valve head broke off and took out bout everything. I decided I'm done spending 10k+ on motors so I went this route.
I won't name names due to the rules.
