zz502 killed my M21 Muncie
:ack:
http://www.zuendler.com/temp/M21-zahnausfall.jpg Is this something I had to expect? I was shifting with 2/3 throttle, from 2nd to 3rd. I was a bit late on the clutch, means I pushed the stick a bit while clutch was not fully released. Then something broke inside... What now? Engine has ~ 550ft/lb. All normal Keisler tranys are rated to 500ft/lb, except the TKO600 and SS700 |
The M21 helical gears are designed to run quiet. Straight cut gears like the M22 are much stronger but whine. The M21 wasn't designed for performance 500" engines.
I have to find out if the SS700 can be delivered without waiting 6 months now. And if it can be put in place without removing the cross member and to do it all in my garage, without a car lift.
Any experiences? I thought also about just restoring the M21 - but I think thats no option, because it will break again. |
contact a company similar to this to upgrade the transmission
http://www.riversidegear.com/muncie-4-speed/ |
If you stay with a Muncie, Autogear offers a lot of upgrades.
wow, Keisler is responding within seconds! They cant give any delivery date for new orders on the SS700. So this option is out.
I won´t stay with the Muncie, because I want an overdrive gear. So only the TKO 600 is left. |
I am easy on my clutch, but take my 550 ft-lb 468 to 6500 and shift quick. TKO600 has been fine with that. My Vette-brother runs 501 RWT with TKO600 and no problems for 2 years. like me, he is also not a clutch-popper.
Originally Posted by zuendler
(Post 1585071893)
RayY on CF runs a 555ci engine with 3.73 and TKO600. I believe he has had that combination for a year or 2. Just recently, he confirmed that it was working fine on a thread here.
I am a few weeks away from running a 540 through my TKO600. With my driving style, I think it will be fine. Obviously, that's not evidence. |
M21 + 3.08 rear end + 285/40/18 Toyos + 565 ft/lbs - 4 years in the car and Muncie is holding-up fine so far (unlike stock engine mounts)
Originally Posted by v2racing
(Post 1585070809)
Trans had it comin'
Autogear also has a gearset that makes 4th an OD.
http://www.autogear.net/pdf/HighPer_..._sheet_t10.pdf |
Zz502 killed my Muncie
I have a rebuilt Muncie with a gear vendors overdrive behind my 496 full roller that dynoed at 635 hp . Very solid very strong and overdrive in any gear plus one clutch-less shift. Rebuilt Muncie $500 GVO $3,000 installation $ 1,500 ? Not too bad. Check out GVO they are even warranted for drag racing.
My $.02 |
T-56 Magnum behind my 496 BBC. 700 ft lb rating, 5th and 6th overdrive.
Quicktime has a conversion bellhousing for the LS spec transmission behind a traditional Chevy engine. Hurst Driveline had a modified QT bellhousing and the parts (throwout bearing sleeve) to allow a mechanical clutch linkage. Had to modify the crossmember (used a BowTie Overdrives T56 unit with slight mods), 1310 billet yoke with removable caps, and custom driveshaft. Used a 73-81 T56 Camaro shifter, rotated the stick part 180 degrees and it fit the stock console perfectly (already had a large center hole from earlier Tremec 3550 swap). I have the version with 2.66 first and .8/.62 overdrive. Works great with my 3.73 12 bolt rear. More info on the Hurst parts here: http://www.chevelles.com/forums/showthread.php?t=325170 |
Shockloads will kill any trans sooner or later.
Owning a TKO600, if I could do it all over again I'd go with a T56.
I have the TKO600 behind a 468 with a 3.55 rear end and 27in tire height. It will lug along at 1400-1500 rpms and 50mph and is extremely happy in the 1900-2100, 65-70 mph range. I can see where some would want an OD gear that is more in the .75 ratio bur for a driver like mine is the .64 is great.
Originally Posted by Shark Racer
(Post 1585089137)
Didn't consider it because I didn't like the idea of messing with the fiberglass and console or the welded up offset shifter. So I bought the TKO. And then immediately got the sawzall out and cut up my crossmember. LOL. |
Originally Posted by Super6
(Post 1585091145)
Why the T56? 6th gear? Torque capacity? What is the torque capacity?
Didn't consider it because I didn't like the idea of messing with the fiberglass and console or the welded up offset shifter. So I bought the TKO. And then immediately got the sawzall out and cut up my crossmember. LOL. That said, the T56 shifts better, does have the extra gear and would have come in at the same price or possibly lower. Speedometer output would have been an issue, but not unsolvable. The lower geared T56 (like in a GTO) would have probably been the better choice for my personal setup. As for torque capacity, 400lb-ft +, depends on the source application. A T56 magnum comes in at 700LB-FT. |
