C5 Z06 front wheel info
I'm looking for the weight of the c5 z front wheel... Also is it Mag? while searching I found this data. According to this it is not mag.. Is this correct?
here is what I found: C5 Corvette Wheel Hard Core Data C5 Corvette Wheels Weight by brand and type 19.2 lbs, front; 21.4 lbs, rear - 97-99 OEM wagon 22 lbs, front; 29 lbs, rear - 97-99 OEM wagon 17 lbs, front; 19.5 lbs rear - 97-00 OEM magnesium 17.5 lbs, front; 19.5 lbs, rear - 97-00 OEM magnesium 18.08 lbs, front; 20.06 rear - 00 OEM standard, thin spoke, high polish 17 lbs, front; 20 lbs, rear - 00 OEM standard, thin spoke, painted, no sensors or centercaps 16 lbs, front; 20 lbs, rear - 01 OEM standard high polish 19.6 lbs, front; 21.4 lbs, rear - 01 Z06 forged 19.2 lbs, front; 21 lbs, rear - 02-04 Z06 cast/spun 24 lbs, 18x10.5 - 00+ repro high polish 28 lbs, front; 32 lbs, rear - Z06 chrome repro 23 lbs, front; 26 lbs, rear - Z06 chrome repro 23.5 lbs, front; 24.5 lbs, rear - Z06 Motorsports, polished 20 lbs, 17x8.5, 58mm offset, front; 23 lbs, 18x9.5, 65mm offset, rear 22 lbs, 18x10.5, 58mm offset, front - HRE 545 w/clear center 27 lbs, 18x12, 74mm offset, rear - HRE 545 w/clear center 24/25 lbs - Z07 wheel weight, front 28 lbs - Z07 wheel weight, rear |
I will weigh the wheels that I have and let you know shortly.
Originally Posted by SEVINN
(Post 1585098401)
Mine are silver painted speedlines with wheel weights, metal valve stem and no center cap and came in at 18.5 pounds. They appear to be normal aluminum to me.
thanks a lot. That makes it tough for me to put my tires on a set of wheels I just bought.. They weigh almost 31 pounds each.... That's a huge difference but I might have to use them to get my contact patch flat:ack:
I got 15lbs out of my car just by swapping in a smaller battery. :thumbs:
Do you still have the Z brakes on the rear ? You could save some unsprung rotating weight by going to base brakes. |
Originally Posted by stanger383
(Post 1585098745)
Originally Posted by PRE-Z06
(Post 1585098908)
The C5Z wheels are not magnesium, did you order C4 ZR1 repos?
Originally Posted by Dragracer_Art
(Post 1585098790)
(Post 1585098013)
For anyone that wonders the weight of the C5Z/hoosier combo. I just pulled my rear drag pack off and they both weigh 43 pounds
C5Z fronts with 315/35/17 hoosiers hoosier lists the weight at 26 for that tire which would make the wheel 17. I'm pretty sure that the wheels are closer to 19 as listed(sevinn said his are 18.5, mine have caps and balancing weights on them). So the tire probably weighs closer to 24 than 26. I weighed the ZR1 wheels and they are 27.3 pounds... So.......... for the difference of 17 pounds I think I'm going to run the ZR1 wheels. What good is a light wheel if I can't get off the line? The contact patch should be much better on this 11 wide wheel |
(Post 1585106017)
weight
(Post 1585098745)
results are in and I am much happier with the heavier wider wheels. I was able to run 20 psi and get my first 1.2x 60'!!!!
That's very fast good work!
(Post 1585098013)
here is what I found: C5 Corvette Wheel Hard Core Data C5 Corvette Wheels Weight by brand and type 19.2 lbs, front; 21.4 lbs, rear - 97-99 OEM wagon 22 lbs, front; 29 lbs, rear - 97-99 OEM wagon 17 lbs, front; 19.5 lbs rear - 97-00 OEM magnesium 17.5 lbs, front; 19.5 lbs, rear - 97-00 OEM magnesium 18.08 lbs, front; 20.06 rear - 00 OEM standard, thin spoke, high polish 17 lbs, front; 20 lbs, rear - 00 OEM standard, thin spoke, painted, no sensors or centercaps 16 lbs, front; 20 lbs, rear - 01 OEM standard high polish 19.6 lbs, front; 21.4 lbs, rear - 01 Z06 forged 19.2 lbs, front; 21 lbs, rear - 02-04 Z06 cast/spun 24 lbs, 18x10.5 - 00+ repro high polish 28 lbs, front; 32 lbs, rear - Z06 chrome repro 23 lbs, front; 26 lbs, rear - Z06 chrome repro 23.5 lbs, front; 24.5 lbs, rear - Z06 Motorsports, polished 20 lbs, 17x8.5, 58mm offset, front; 23 lbs, 18x9.5, 65mm offset, rear 22 lbs, 18x10.5, 58mm offset, front - HRE 545 w/clear center 27 lbs, 18x12, 74mm offset, rear - HRE 545 w/clear center 24/25 lbs - Z07 wheel weight, front 28 lbs - Z07 wheel weight, rear Bill |
