The word VOLT showing on my odometer
I have a 93 c4 and recently the battery light on the center console comes on and off occasionally and only for a second. Tonight the word VOLT appeared on the odometer. Does this mean it's time for a new battery?
Changling mode. Tomorrow it will morf into a Volt. :D
Yes, check the battery and alternator for proper voltage. |
Originally Posted by JrRifleCoach
(Post 1585187361)
Yes, check the battery and alternator for proper voltage. Barring that, what volts is your car charging at? |
Charging should be between 13.8 and 14.6 depending on how long the car has been running....WW
Originally Posted by Y-ME
(Post 1585187653)
Incorrect, it is poor quality subliminal advertising to buy a volt. Gm wants their 40k. Head immedietly without thinking to your local GM dealer and Buy a Volt to turn off light.
Originally Posted by davewhtt
(Post 1585188164)
:ack: Im screwed mine is flashing PRIUS!
I see is changing into a prius.
Did it look like this last night? http://cocooncradle.files.wordpress....k-cocoons1.jpg |
