C7 Jack Pucks In Stock On Sale! Leave-In Style, Easy Install
As many of you know, you risk damaging your Corvette when you or a shop tries to lift it without have proper jack pads in place. Why take the risk of getting your prized possesion back with damaged rockers? Our new, lightweight ABS plastic Jack Pucks will save you the aggrevation and you'll know they are always there. Take it to the dealer, a performance shop or the tire shop without worries. You'll always have these pucks ready to protect, invisible to everyone! Sold as a set of 4, we have these marked down to: $49.99 A SET! Click here to order: http://www.corvettemods.com/Corvette...R-_p_9265.html http://imagizer.imageshack.us/v2/640.../dsc09969a.jpghttp://imagizer.imageshack.us/v2/640...9/85641208.jpg |
pucks
They go in easy and look good and nice people to work with.
Originally Posted by gkwpnut
(Post 1586445582)
Originally Posted by Zmoy2
(Post 1586504637)
Are they specifically for the c7? They won't fall off or interfere with the body panels?
2 Attachment(s)
Installed a set and walked away. They work great and can't be seen unless you get down low and look for them. I'll post photos shortly. :cheers:
Here you go: |
Bought a set from you as well. Couldn't be happier! Easy to install, stays solidly in place and is hidden. Would buy again!
How do they actually fasten in ?
And, are you sure they won't come out on their own ????? Being plastic, are they really strong enough to support 900 to 1000 lbs ? |
Originally Posted by NTMD8R
(Post 1587687076)
will these work on the z06? i realize that the aero is in the way of even geeting a low profile jack under the car. i use a ramp to get it part way up b4 jacking, so only the frame hole where they insert may be an issue.
Originally Posted by CONMAX
(Post 1588751784)
Originally Posted by corvettemods1
(Post 1588751848)
We haven't tested it yet. If you have an unobstructed area where they attach it should work fine
Originally Posted by slownlo
(Post 1589146520)
are they easy to remove if needed?
sorry to be an anal pain . . . . do they fit the with the stage 3 side skirts?
Thanks, had them on my 2014 Z51 and loved them. |
Originally Posted by oldfoggy
(Post 1589409059)
