[C6] Dorman Speed Bleeders pt number 12706
Hello all,
I'm preparing for my first track day and need to get rid of the factory fill brake fluid and was wondering if anyone had any experience with Dorman part number 12706 that you can get from part stores like OReilly and Autozone; supposedly they fit as they are m10 x 33MM Unfortunately I don't have time to order a motive bleeder or anything like that before my track do so I was wondering what you guys that don't have a helper do to get your brakes flushed by yourself; just a hose in a bottle with some brake fluid at the bottom? Thanks! :cheers: |
i love speed bleeders. Dorman is right down the street from where I live :P
Did you look at the brake bleed section: http://forums.corvetteforum.com/auto...e-learned.html A simple catch bottle with a wire hook to hang it works great. I suggest you have 2 bottles when you are in a rush at a track event. Jack the car, pull both front wheels. hang two bottles. grab the 10mm and just lightly crack the speed bleeders. LIGHTLY CRACK it open, and then pump away! TIghten and then hit the second one. MAKE SURE you keep an eye on your reservoir when doing this method. ONE time you let air into the master and your a gonner. Most events you only need to bleed all four befre the weekend at HPDE. During the weekend the fronts need rebleeding at least once or twice in the weekend if you are using a race pad that generates big heat. |
I did not look at that sticky; what a ton of good info.
This is my first trackday and it's 2 20 minute sessions so I'm just prepping the car this weekend and I think I'll be alright. I'll see if I can track down a set of the dorman bleeders to make it easier on myself. Thank you very much. |
