On the fence about changing your brake fluid? Check this out.
On the fence about changing your brake fluid? Check this out. http://forums.corvetteforum.com/atta...11709122_n.jpg http://www.xplosiveperformance.com/t...axx=300&maxy=0 Motul RBF600 is the best high-temperature Brake Fluid and preferred by many tuners and race teams. Its specifications and labratory results exceed that of DOT 5 silcone based fluid, but still retains the benefits of Glycol based fluid by lubricating the ABS pump and not deteriorating caliper and Master cylinder seals 100% Synthetic Brake and Clutch fluid. Compatible with all Dot 3 and 4 fluids. Specifically designed to resist the high temperatures of actuated (steel or carbon) racing brakes and clutch systems. Extreme high performance polyglycol brake fluid. Far exceeds the standards of DOT 4. Each bottle is filled with Nitrogen, increasing shelf life and eliminating contamination while factory sealed. Extremely high dry boiling point 594F(312C) helps prevent vapor lock and brake fade during hard use, with excellent recovery time. Wet boiling point 401F(205C). 500ml bottles 1.05 pint $17.95 each http://www.xplosiveperformance.com/M...00-_p_648.html Motul RBF600 Case of 12 http://www.xplosiveperformance.com/M...12_p_3237.html $204.12 Motul RBF660 racing DOT4 http://www.xplosiveperformance.com/M...T4_p_2403.html $27.59 Motul RBF660 racing DOT4 (Case of 12) http://www.xplosiveperformance.com/M...12_p_3238.html $331.08 |
100% Synthetic Brake and Clutch fluid. Compatible with all Dot 3 and 4 fluids. Specifically designed to resist the high temperatures of actuated (steel or carbon) racing brakes and clutch systems. Extreme high performance polyglycol brake fluid. Far exceeds the standards of DOT 4. Each bottle is filled with Nitrogen, increasing shelf life and eliminating contamination while factory sealed. Extremely high dry boiling point 594F(312C) helps prevent vapor lock and brake fade during hard use, with excellent recovery time. Wet boiling point 401F(205C). 500ml bottles 1.05 pint $17.95 each http://www.xplosiveperformance.com/M...00-_p_648.html Motul RBF660 racing DOT4 http://www.xplosiveperformance.com/M...T4_p_2403.html $27.59 Motul RBF660 racing DOT4 (Case of 12) http://www.xplosiveperformance.com/M...12_p_3238.html $331.08 |
http://s3-eu-west-1.amazonaws.com/mo...jpg?1335379295http://s3-eu-west-1.amazonaws.com/mo...jpg?1335370878http://s3-eu-west-1.amazonaws.com/mo...jpg?1350666590
http://www.xplosiveperformance.com/M...00-_p_648.html http://www.xplosiveperformance.com/M...12_p_3237.html http://www.xplosiveperformance.com/M...T4_p_2403.html |
Started on Monday November 18, 2013 We have launched our XP Motorsports/Xplosive Performance Customers Reward Point Program Reward Point Program Explanation & FAQ What is the Reward Point Program? To thank you all for your continued support and to offer you future incentives we would like to give you something back, this is why we have launched our great XP Motorsports Customers Reward Point Program. Our Customers Reward Point Program is as simple as it sounds. While shopping at XP Motorsports/Xplosive Performance you will earn Reward Points for the money you spent. Once earned, you will be able to use those points to pay for future purchases at XP Motorsports/Xplosive Performance. How does the Program work? When you place an online order, the total amount of the order will be used to calculate the amount of points earned. These points are added to your Rewards Points account. For every ($1) Dollar you spend you will earn ($0.10) for future purchases. All reward points are listed in your account and will stay there until used by you. Ready for you to spend on whatever you want. Reward points will expire after two (2) years but can be accumulated during that time until you decide to use them. You must login to your account in order to view the status of your points. During the checkout process you'll be able to pay for your order with your rewards points balance. Points and Values For every $1.00 spent at XP Motorsports/Xplosive Performance you will earn .10 point. For example: Buy a set of Pads for $301.00 = 30 Reward Points. Each product will have a Reward point valve. Along with the add to cart box you can elect to pay for your next purchase with your Reward Points Redeeming Shopping Points If you have a balance in your Rewards Points Account, you can use those points to pay for purchases made at XP Motorsports/Xplosive Performance. On your next purchase you can check the [Redeem this Item for (x) points]. You can then redeem your reward points. Once confirmed your order will be shipped, your Rewards Point account will be updated and the points used will be deducted from your balance http://s3-eu-west-1.amazonaws.com/mo...jpg?1335379295http://s3-eu-west-1.amazonaws.com/mo...jpg?1335370878http://s3-eu-west-1.amazonaws.com/mo...jpg?1350666590 500ml bottles 1.05 pint $17.95 each http://www.xplosiveperformance.com/M...00-_p_648.html Motul RBF660 racing DOT4 http://www.xplosiveperformance.com/M...T4_p_2403.html $27.59 Motul RBF660 racing DOT4 (Case of 12) http://www.xplosiveperformance.com/M...12_p_3238.html $331.08 |
