Originally Posted by MrWillys
(Post 1585383892)
Mine is a B&M and they're separate.
One allows a load to pass to the starter in Park / Neutral. One provides a signal for reverse lights Another provides a ground signal when in Park / Neutral. My B&M Quiksilver only has the 2 , the reason why I never connected the ECM interface As you note , the stock 6 wire switch is 3 separate switches in one unit NSS , backup , and ECM http://i171.photobucket.com/albums/u...al/Shifter.jpg |
Originally Posted by vetteoz
(Post 1585384839)
Does your B&M have provision for the 3 switches ?
My B&M Quiksilver only has the 2 , the reason why I never connected the ECM interface As you note , the stock 6 wire switch is 3 separate switches in one unit NSS , backup , and ECM http://i171.photobucket.com/albums/u...al/Shifter.jpg No cute schematic that you're known for? |
(Post 1585384925)
http://i171.photobucket.com/albums/u...trical/TCC.jpg http://i171.photobucket.com/albums/u.../Starter-1.jpg |
(Post 1585382964)
There are documented faults in the FSM
(Post 1585382964)
Just repeating what I already stated above in post # 8
(Post 1585382964)
Seeing the TCC is only activated when the car is in motion unlikely it will engage with the car stationary regardless of whether the ECM
knows if the trans is in or out of gear............ Evidently I have worked and repaired weird Corvettes that have problems that no one else has.
(Post 1585382964)
Which both Cliffy and I previously stated ;
you were the one implying that bypassing the NSS being discussed in this thread "also this switch is used by the computer to tell it if it is in (Park/Neutral)" would affect the ECM :crazy2: I did not write it would effect the ECM. What you got out of what your read is just that. It is not damaging the ECM...the ECM would still be performing its job...which is to maintain the engine, respond to inputs needed to keep it running smoothly and show possible trouble codes due to incorrect inputs that the ECM need to keep the engine running.....unless you feel a trouble code is "effecting the ECM". Like MrWillys wrote...it is 3 switches in one. Park/Neutral,Neutral/start and backup light switch. DUB |
(Post 1585365384)
Connect the two wires together. I would not do this other than for testing though. It's dangerous to have it start in gear. Don't ask how i know this?
