C7 fast list!
Haven't seen one yet and with the C7's going faster and faster I figured it was time to start up a Fast list.
I copied and pasted from Rangers thread in the C6 Z06 section. Wasnt much I had to modify to apply to the C7. I'll do my best to update as often as possible as the posts come in. Here are the copied rules.... The Fast List, found at the end of Post #1 of this thread, is open for additions as submissions are received and validated. The Fast List has five sub-lists. Bone-Stock on Stock Tires. This means completely stock with no performance changes whatsoever; stock exhaust, stock airpath, stock “untuned” and ""never-tuned" computer (ECU/PCM), etc. Bone-Stock, except Non-Stock Tires including drag radials. Otherwise, the same requirement as above. Bolt-Ons without Internal Engine Modification (e.g. modified air-path, headers, PCM-tune, aftermarket clutch, non-stock rear gears, skinny front tires) Internal Engine Mods plus Bolt-Ons (e.g. stock displacement with bolt-ons plus heads and/or cam) Power Adders (Nitrous, Turbo, Supercharger) and Non-Stock Displacement Rules: In proposing submissions for inclusion on the list, please follow these simple rules Rule #1. Post the details of your quarter-mile pass using this template: Note: your submission won't be acted upon unless it is in the format below. This requirement applies to each new Personal Best. Year of the C7: Tires used on the pass: Performance Mods (if any): Category submitted for: 60'............. 330'........... 660'........... 660’ mph... 1000'.......... 1320'.......... 1320’ mph… Name of the track: Date of pass: Weather conditions: (include Density Altitude, if known): Image of complete Time Slip: Link to Video: Rule #2. Times that may qualify for the top-20 in each category require posting of an image of the complete time slip. If you lack the ability to post an image, contact me via PM, and I will help you. Edit for Clarification (Sep 3 2007): "time slip" means full time slip. Must include date/time of the pass and customarily includes identification of the track issuing the slip. Image should be in the vertical orientation and the numbers must be legible. Edit for Clarification (Jan 10 2011) A time slip is encouraged for all submissions as a means of improving documentation of accomplishments and increasing credibility of the Fast List. Rule #3. Track times will not be corrected for weather or track altitude. Those elements can be noted in the comment portion of the submission to clarify the conditions under which the run was made. If interest merits, we can include a single category for fast times at tracks with altitudes, say, above 3000’ for the official track elevation. Please let us know if there is interest in such a category. Rule #4. All members are invited to submit his/her times on this thread. The top 50 or so for each category will be included in the Fast List. Only one pass per member per car-model per category will be included on the Fast List. Rule #5. In the event two members submit a 1320’ ET identical to the thousandth of a second, the tiebreaker is the higher 1320’ mph. Rule #6. (Oct 20 2010): Stating explicitly a rule applied to all submissions since the Fast List's inception, in order for your track results to be included on it, they must be plausible, probable and credible. The time slip must match the capabilities of the car. Clarification (Oct 20 2010): A car with a tuned (modified file) PCM or a non-OEM PCM is not eligible for either of the two stock classes thereafter. This means once tuned, always tuned. ======================================== ===================================== The C7 Fast List Last Updated: July 20, 2016 ================== Bone-Stock on Stock Tires ================== Rank~~ E.T.~~ Trap~ 60'~ Driver~~~~~ M.Yr. Details 1~~~~11.372~~119.94~~1.623~wfarmer.z~~~~'14 A6 Z51 (Post#275) 2~~~~11.377~~122.91~~1.71~brent eb02~~~~'15 A8 2Lt (Post#212) 3~~~~11.496~~118.96~~1.683~SNORMAN~~~~'14 A6 (Post#4) 4~~~~11.524~~119.52~~1.685~10mm~~~~~~~'15 A8 Z51 (Post#439) 5~~~~11.585~~120.08~~1.716~VNAMVET~~~~'14 A6 Z51 NPP (Post#21) 6~~~~11.630~~118.76~~1.718~Old Goat~~~~~'14 A8 Z51 NPP (Post#578) 7~~~~11.743~~119.05~~1.745~jrwood~~~~~~'14 A6 non-z51, with NPP, Used launch control (Post# 84) 8~~~~11.813~~118.09~~1.760~only9balls~~~~'16 A8 Z51, 91 Octane (Post#588) 9~~~~11.823~~119.22~~1.845~pettevette~~~~'15 A8 ZF1, NPP, 2.41 Gears (Post#531) 10~~~~11.889~~118.31~~1.795~Fore58~~~~~~'14 A6 Non Z51 Convertible (Post#254) 11~~~~11.924~~119.59~~1.836~jacksnorm~~~~'15 A8 1LT (Post#504) 12~~~~11.947~~117.17~~1.806~The Rock1~~~~'14 A6 Z51, 2LT, no NPP (Post#364) 13~~~~11.955~~119.62~~1.919~Kyle Lemish~~~~'14 M7 non Z51 and no NPP (Post#13) 14~~~~12.074~~116.79~~1.928~jb306y~~~~~~'14 M7 Non-Z51, M7, NPP, launch control (Post# 85) 15~~~~12.077~~116.46~~1.869~bigsapper~~~~'16 A8 non Z51, NPP, Launch Control (Post#636) 15~~~~12.164~~116.31~~1.938~Greg Quillen~~~'14 M7 Z51, Has NPP (Post#15) 16~~~~12.217~~116.88~~1.978~nfcooper~~~~~'14 A6 Z51 MR NPP Track sport2, launch off idle 17~~~~12.573~~112.73~~1.996~Baron7700~~~~'14 M7 Z51 NPP stock tire psi. Track mode, full traction on. ======================== Bone-Stock except Non-Stock Tires ======================== Rank~~ E.T.~~ Trap~ 60'~ Driver~~~~~ M.Yr. Details 1~~~~11.311~~121.21~~1.647~wfarmer.z~~~~'14 A6 Z51 with MT drag radials (Post#218) 2~~~~11.719~~119.38~~1.731~robe38~~~~~~'14 M7 Z51 with NPP 315/30/18 Hoosier Drag Radials (Post#52) 3~~~~11.724~~119.52~~1.775~Kyle Lemish~~~'14 M7 MT ET Streets, non Z51 and no NPP (Post#13) 4~~~~11.745~~116.39~~1.675~TonyC@RLMS~~'14 M7 Z51, 345/35/18 MT on ccw 18" wheels (Post#37) =============================== Bolt-Ons without Internal Engine Modification =============================== Rank~~ E.T.~~ Trap~ 60'~ Driver~~~~~ M.Yr. Details 1~~~~10.89~~124.79~~1.57~Ls2000~~~~~~~~~~~~14 A6 TSP headers, AFE intake, tune, E85, CCW's front 17-4, rear 275-40-17 MT (Post#572) 2~~~~11.04~~125.24~~1.59~jacksnorm~~~~~~~~~~15 A8 ARH LT, 3" catted x, HPA Tune, AFE CAI, E85, Nitto NT555R 305/18's & Weld 17" Skinnies(Post#547) 3~~~~11.16~~124.38~~1.70~Cajun@BER~~~~~~~~~15 A8 TSP headers, AFE CAI, BER ported intake/TB, BER tune, NT05R (Post#597) 4~~~~11.17~~126.92~~1.30~Zmoy2~~~~~~~~~~~~14 M7 ARH headers, e85 tune, BF Goodrich drag radials (Post#593) 5~~~~11.19~~123.56~~1.76~yonks8365~~~~~~~~~15 A8 NT05 drag radials, Cai, E85 (Post#553) 6~~~~11.21~~123.75~~1.72~10mm~~~~~~~~~~~~15 A8 Z51 ARH Midlength, AFE CAI, Tune (Post#542) 7~~~~11.32~~120.78~~1.63~wfarmer.z~~~~~~~~~~14 A6 Z51 K&N filter, 4 1/2 inch Weld wheels, NO TUNE (Post#292) 8~~~~11.33~~122.28~~1.62~Complete Street~~~~~~14 M7 NPP, Kooks 7/8, Tune, Catless, MT Radials (Post#482) 9~~~~11.47~~119.32~~1.68~TuneTimePerformance~~~14 M7 ARH/Tune/Z51/NPP 10~~~~11.57~~121.78~~1.82~JJFormato~~~~~~~~~~14 M7 Z51 Modified airbox, ported manifold & TB, Formato tuned. Hoosiers W/C5Z wheels(Post#94) 11~~~~11.67~~120.01~~1.74~~~JB~~~~~~~~~~~~14 M7 ARH, Modified airbox, ported intake manifold & TB, Formato tuned MT drags on C5Z (Post#74) ======================== Internal Engine Mods plus Bolt-Ons ======================== Rank~~ E.T.~~ Trap~ 60'~ Driver~~~~~ M.Yr. Details 1~~~~10.573~~129.34~1.520~Ben@WeaponX~`'14 A6 427, 3400 converter, M&H 325's (Post#541) 2~~~~10.667~~127.39~1.527~LMR~~~~~~~'14 A6) Heads/Cam 3~~~~11.392~~123.29~1.911~ChucksTuning~'14 M7 VVT cam/AFM delete, Kooks 2" headers, 3" B&B PRT, Halltech stinger. (Post#120) 4~~~~11.672~~126.19~1.975~Mike@NewEra~ '14 M7 stock tires, NEP VVT Cam, ARH mid length headers, NEP exhaust D/A +2000 (Post#114) ============================== Power Adders (Nitrous, Turbo, Supercharger) ============================== Rank~~ E.T.~~ Trap~ 60'~ Driver~~~~~ M.Yr Details 1~~~9.48~~156.57~~1.611~LMR~~~~~~~~~ '14 M7) Twin Turbo (Post#250) 2~~~9.72~~137.55~~1.358~LS2000~~~~~~~~'14 A6 200 Shot, TSP Headers, AFE intake, E85, CCW skinnys and 275-40-17 MT 3~~~9.74~~145.94~~1.563~JTMMotorsports~~'15 A8 ARH 1 7/8" no cats, NPP, ECS 1500, 3.75 pulley 13.5#'s, Alky kit, JTM Cam, E85, 315/35/18 M/T DR's (Post#457) 4~~~9.95~~138.20~~~1.544~Dave01GT~~~~~~'15 A8 305/35/19 Mickey's A&A Blower, Small Cam/DoD delete, Long Tubes, Meth (Post#530) 5~~~9.96~~141.22~~~1.644~Pete@ChampionMotors '15 A8 Z51 A&A YSi, Champion Cam, ARH Headers, MT 18'DR (Post#526) 6~~~9.99~~132.7x~~~1.403~LMR~~~~~~~~~~'14 A6) Heads/Cam/150shot 7~~~10.00~139.85~~~1.541~brent eb02~~~~~~'15 A8 Ecs 1500 meth and Texas speed headers mt 315's (Post#591) 8~~~10.03~146.67~~~1.763~stangkilrproductions '14 M7 Stock LT4, Procharger F1a 14lbs, Cam, DYAD clutch, ignite e90 and meth, Cordes Tune (Post#582) 9~~~10.13~138.97~1.441~Ben@WeaponX~~~~'14 A6 427, NOS, 3400 converter, M&H 325's (Post#181) 10~~~10.18~131.23~1.434~Jimsgn~~~~~~~~~'14 A6 Z51, 417CI, LME Heads, ECS 1500,10psi, LS7 Lifters, BTR Springs, C5R Chain, Alky Meth, 3500 Stall, ARH 7/8, Catless M&H 275/45/18(Post#149) 11~~~10.17~140.56~1.610~Complete Street~~~'14 M7 A&A YSI Kit 10psi slipping belt, Meth, Kooks Headers, MT 285/35/18 (Post#537) 12~~~10.19~140.33~1.611~RyneZ06~~~~~~~'14 A6 Cam, Procharger P1 10lbs, ARH LT, Alky meth, Cms tuning, Hoosier drag radial (Post#304) 13~~~10.20~144.03~1.669~Vengeance Racing '14 M7 ECS blower, 14psi, Alky meth,VR Cam, ARH 1 7/8 W/CATTED X pipe Toyo 888R 315/35/20 (Post71) 14~~~10.25~140.33~1.640~JJFormato~~~~~~'14 M7 A&A Supercharger 6.5 psi, Fasterproms Heads/Cam, 93 Octane (Post#269) 15~~~10.33~136.93~1.671~c6switchblade~~~~'14 M7 ECS 2200sl, 2" ARH, Alky single nozzle 265/18 MT ET Streets (Post#486) 16~~~10.39~131.48~1.419~C7LT1~~~~~~~~~'14 A6 Tune, Converter, 150 shot m/t 19's. (Post#64) 17~~~10.56~131.35~1.633~kakashi~~~~~~~~'14 A6 A&A Supercharger, TSP LT headers, Alky Meth 9psi Hoosier 315/30/18, (Post#456) 18~~~10.57~129.96~1.554~Dameian~~~~~~~'14 A6 Z51, Pfadt Kit 8psi, ARH, 18" Forgeline Drag pack with 325/40/18 M&H Radials (Post#104) 19~~~10.61~132.13~1.713~Melgotboost~~~~~'14 A6 Non NPP, Tires stock, stock tire pressure, ECS Novi1500 ARH, Alky meth (Post#348) 20~~~10.64~135.13~1.849~FRANS96SS~~~~~'14 M7 Headers/Tune/150shot 21~~~10.73~132.90~1.813~"BoneStock"~~~~~'14 M7 20's with 315 r888s. ECS kit with restrictor removed, TSP Headers, meth (Post#459) 22~~~10.83~131.02~1.666~2highpsi~~~~~~~'15 A8 Z51 Magnuson Heartbeat, LT4 pump/injectors ET Street S/S 285-40-18 (Post#640) 23~~~10.84~130.55~1.716~10mm~~~~~~~~~'15 A8 Z51 Midlength Headers, AFE CAI, 100 shot (Post#514) 24~~~10.93~127.55~1.675~MIGHTYM0USE~~~'14 M7 A/A base kit, AFE headers, Meth, Tune, 305 19" NT05R (Post#498) 25~~~11.06~134.78~1.974~jsb08Z~~~~~~~~'14 M7 Z51 ECS supercharger 12psi, ARH headers, Meth, LMR breather kit (Post#159) 26~~~11.19~129.98~1.862~Greg Quillen~~~~~'14 M7 Z51, NPP, ECS Supercharger, ARH Headers, Pilot Super Sports (Post#157) 27~~~11.69~122.85~1.794~blue_bomber697~~'14 M7 Z51 ECS Supercharger, American Racing headers and X-Pipe (Post#629) 28~~~ Post em up! |
Looking forward to seeing the results between the A6 and M7!
Nice. I may get some 8th mile times on Thursday.
Year of the C7:
Tires used on the pass: Stock OEM Michelin Pilots Performance Mods (if any): None Category submitted for: Bone Stock on Stock Tires 60'.............1.683 330'...........4.807 660'...........7.389 660’ mph...94.61 1000'..........9.613 1320'..........11.496 1320’ mph…118.96 Name of the track: Date of pass: 11/4/13 (Atco timeslips dates are incorrect) Weather conditions: (include Density Altitude, if known): ~1200'-1500' http://imageshack.us/a/img820/9346/rq7p.jpg http://imageshack.us/a/img853/4773/8tg5.jpg Video of 11.67 pass made a few weeks earlier in ~400' DA at Atco: S. |
We should have the top time for internal engine mods plus bolt ons. Same car that went a 9.99 went a 10.66 at 127mph on motor.
Updated! Thanks guys.
Seriously a 250 shot??
You're keeping rule #7?
Originally Posted by Devilish34
(Post 1585412211)
You also may want to remove the * note about conversion to an auto since it is not needed. Looks good and thanks for taking it on. :thumbs: |
Just asking: Shouldn't drag radials be added to the list of mods for the existing entries?
Another recommendation would be to list the post number in the thread next to the time on the list (in parenthesis) so that people can go directly to that post and get details.
S. |
I think the C7 needs a slow list - who's not running 11s and pulling 1.7 or better 60fts bone stock? What a car.
There should be footnotes as to M7 V A6? This was pretty good air, Drag times lists about -700 for both passes.
I took my M7 non Z51 and no npp option, to MIR today Bone stock on stock tires: 11.95@119.62 Stock on 315/35/18 mt et street II: 11.72@119.52 Date is correct on timeslips, but time is 1 hour off (jason must not believe in daylight savings time) https://scontent-a-iad.xx.fbcdn.net/...77994561_n.jpg This is a very hard car to drive fast at a drag strip, it definately needs TQ management tuned out! |
Updated.
1 Attachment(s)
Year of the C7: 2014
Tires used on the pass: Stock Performance Mods (if any): Stock (Options are: M7, Z51, Has NPP, Has Mag suspension) Category submitted for: Bone Stock - Stock Tires 60'............. 1.938 330'........... 5.248 660'........... 7.941 660’ mph..... 92.32 1000'.......... 10.221 1320'.......... 12.164 1320’ mph….. 116.31 Name of the track: Island Dragway Date of pass: 11/3/2013 Weather conditions: (include Density Altitude, if known): DA -37 was 52 degrees by this run. Image of complete Time Slip: Attachment 47747589 Link to Video: I can see a lil more left in it maybe another tenth. You see in the video for the first half a second I left a little soft before I got on it. I had trouble earlier with wheel spin. Track was cold not many people running. After this run I had to leave the GF was cold. |
Originally Posted by Greg Quillen
(Post 1585473133)
Tires used on the pass: Stock Performance Mods (if any): Stock Category submitted for: Bone Stock - Stock Tires 60'............. 1.938 330'........... 5.248 660'........... 7.941 660’ mph..... 92.32 1000'.......... 10.221 1320'.......... 12.164 1320’ mph….. 116.31 Name of the track: Island Dragway Date of pass: 11/3/2013 Weather conditions: (include Density Altitude, if known): DA -37 was 52 degrees by this run. |
Originally Posted by racerns
(Post 1585476070)
I can't watch the video right now but you may want to add if the car is a Z51, has npp, and if it is an A6 or M7. I am assuming M7?
M7, Z51, Has NPP, Has Mag suspension. :sadangel: |
Guys question? A bone stock C7 with above average driver. In the 1/4 whats faster the automatic or the 7speed?
Originally Posted by Craig's corvettes
(Post 1585542144)
Not to mention if will launch and shift perfect and fast everytime. |
Autos are definitely more consistent and far easier to launch.
Personally, I think drag racing an auto is pretty much fun for 2 runs and after that I'm bored. I may get inconsistent runs with a manual, but I have a lot more fun doing it. |
