Which are right tires for 1971
Existing tires need replacement. They are 235/60/15. Book calls for 235/70/15.
Also can I think they said 255/70/15 fit with no problems. I would like to go a little wide and the 255's are???? Any help. |
Re: Which are right tires for 1971 (John D.)
My 79 has 255/60R15s
:cheers: |
The correct Tire Size for 71 is F70-15. According to this chart I found that is
equivalent to P205/70R15 http://www.turbinecar.com/tires.htm [Modified by Red71-454, 12:01 AM 7/10/2002] |
Re: Which are right tires for 1971 (Red71-454)
I like 255/60/15's on the rear, but hated them on the front, had problems with wondering and rubbing on sharp turns. I now have 225/60/15's on the front, MUCH BETTER.
Re: Which are right tires for 1971 (71,454,4spd)
I run 245/60/15 BFG Radial TAs on my 72 with no problems whatsoever. Good tire and nice ride.
I was told the closest size to the F70's were 225-70's. I replaced GR60's on the 69 with the 225-70's and it was a night and day difference-so much so I never installed the PS setup I bought for the car. I'm going to run the same tire on the 72.
Gary |
The correct Tire Size for 71 is F70-15. According to this chart I found that is equivalent to P205/70R15 http://www.turbinecar.com/tires.htm [Modified by Red71-454, 12:01 AM 7/10/2002] |
I run 255-60-15's front and rear, no problems with rubbing.
Re: Which are right tires for 1971 (gq82)
FYI....I have P255/60R15 Goodyears GTII on my '72 with no problems....
Note: Sig shows P245/60R15's that were on the car when I bought it. I've since changed to the 255's. |
265/60/15s in rear and 235/60/15s in front. No problems.
I got my BFG Radial TAs from NTB a few years ago, and they said the book called for P225/70/15 so that's what I got. Now I'm sorry I didn't research it a little better because the 70s seem to "tall". When I replace them I'm going for 60s and probably wider too.
The correct Tire Size for 71 is F70-15. According to this chart I found that is equivalent to P205/70R15 http://www.turbinecar.com/tires.htm [Modified by Red71-454, 12:01 AM 7/10/2002] Actually the correct current day service replacement size is P215/70R15. I agree that the wider tires wander more. |
I have a 1971 corvette stingray and it currently has the BF Goodrich tires size P225/70R15 100S should I keep that exact size or change size I really want the car to drive and ride good . Thank you ! Lance |
I would like to see pictures of actual corvettes with P255/60R15 tires and also corvettes with P215/70R15 tires for comparison purposes.
Just look at the 1979 Corvette sales brochure for the L82 Vette - it came stock with P255/60R15 tires.
https://cimg9.ibsrv.net/gimg/www.cor...fbd11d76ed.jpg From the side, the two tires you mentioned will look the same - they are the same diameter within 0.10". The only difference is in the width: The 255's are 10" wide, and the 215's are 8.5" wide. :thumbs: Lars |
My '69 with BFG 255/60 R15's on rear, and I believe 225/70's on the front.........see sig pic.
Correct tires for a 1971 C3 were F70-15's. The equivalent of that in a radial tire is 215R70-15. But, folks like wider tires than that...and when you go 'wider', the tire diameter gets larger...and the speedo calibration goes whacko. 235R60-15's are nearly the same diameter as the F70-15; and 235 width tires are the widest that will ALWAYS have clearance to the frame and body parts in the front end of '68-77 cars. Many will accept 245's without rubbing; some will take 255's. Front end wheel wells were opened up in 1978, so '78-82 will take larger tires up front [and rear].
I run 225/70-15 rear & 215/70-15 front on my '72 Coupe. Rides and handles great!
https://cimg1.ibsrv.net/gimg/www.cor...270012ff9c.jpg |
Subscribe |
will the stock rally wheels on 71 accept 255 wide tyres in the back? Or do they fit even wider tyres on stock wheels?
