Originally Posted by DJF
(Post 1596590745)
Before:
https://cimg1.ibsrv.net/gimg/www.cor...4dac59d1e7.jpg After: https://cimg3.ibsrv.net/gimg/www.cor...20f47175ad.jpg AR Racing Torq Thrust II 17x8 5x4.75 and Nitto NT555 G2 255/50R17. Both before and after are the same exact height. |
Originally Posted by a striper
(Post 1597861393)
https://cimg8.ibsrv.net/gimg/www.cor...9b0e0868a4.jpg
https://cimg0.ibsrv.net/gimg/www.cor...9b5862d0da.jpg I like the ride and appearance of 15s but the better tires available in larger diameter do well in corners. |
Originally Posted by TedH
(Post 1597865337)
What are specs on your wheels/tires and did you have any mod's to make the wheels and tires fit? Any spring, trailing arm or other changes?
parking brake cable and switched to a narrow rear spring. Don't remember the rear back spacing, front is 4". |
Originally Posted by Hpozzuoli
(Post 1587055200)
I have the original wheels in storage, but wanted something different. I ended up with wire wheels. They are 15's. Front rubber is 255/60/15 and the rears are 275/60/15.
I think i need to lower it a bit
Yes you do. :D
This is after, 15x7 rally before, now 15x8.5 235/70/15
https://cimg1.ibsrv.net/gimg/www.cor...7324507e89.jpg
Yea i went from 15x8 with 235 on the front and 255 on the back to 17x8 with 225 on the front and 235 on the back. They ride a lot nicer but needs to be lower so will get 8 inch bolts 4 the back and see what i can do with the front. |
(Post 1597865333)
Did you have any spacer, t-arm, spring or brake mods to make them fit?
They look great! Can you fit a full sized (255 60 15) spare (Original Rally rims) in the spare wheel well on a 1972 C3? TIA
Originally Posted by tanguy
(Post 1594941692)
Hello from Paris FRANCE it's my new combo KOMPRESSION in 12/18 335/30/18 and 10/18 275/35/18
It's perfect combo and realy very good job. https://cimg3.ibsrv.net/gimg/www.cor...0f9552ce28.jpg https://cimg2.ibsrv.net/gimg/www.cor...2a415c4b9a.jpg https://cimg4.ibsrv.net/gimg/www.cor...18ea6ef64b.jpg Soundbite |
Very Nice!!!
New Shoes for the C3KR
In the process of doing a lot of things, but since I'm working on brakes and suspension, I didn't want to put the old wheels and tires back on. 15x8 US Mags Indy U101 with 275.60.15 Cooper Cobra Radial GT's, with their billet spinners in the rear. I just stuck the other rear tire up front to see what it would look like. Cooper doesn't make a 260.60.15 anymore, so 255's up front will have to suffice.
https://cimg0.ibsrv.net/gimg/www.cor...111d156cd0.jpg https://cimg6.ibsrv.net/gimg/www.cor...735edfd715.jpg In |
AutoX in the works
https://cimg7.ibsrv.net/gimg/www.cor...530d50d666.jpg
https://cimg7.ibsrv.net/gimg/www.cor...5895a20497.jpg My C6 split spokes on my wifes C3 AutoX car |
Originally Posted by Bobby Hux
(Post 1585944096)
My 77, with Boss 338 18x8 with 4.5 back spacing 255 45 18 nitto 555 tiresAttachment 47759835
Nice fitment ! what size adapters ? 2 inch ?
Milan 454 ...what size spacers:hide:
3.1 inch and 2.9 inch from motorsport-tech. Wheel and hub centric. JR can hook you up. These adapters are lifetime warranty and survived MANY track events. BTW 2 coils cut from front springs. 10inch bolts in the rear stock spring
https://cimg0.ibsrv.net/gimg/www.cor...117038d397.jpg
https://cimg1.ibsrv.net/gimg/www.cor...dd0f532062.jpg https://cimg2.ibsrv.net/gimg/www.cor...8365b2756e.jpg New shoes... 17x8 with 4" Backspacing on the fronts running Nitto 555 255/50ZR17 and 18x9.5 with 5" backspacing on the rear running Nitto 555 285/40ZR18's. I ended up putting on 1/4" spacers on the rear to clear the e-brake cable. I needed to remove the e-brake brackets as well. They will be relocated to the top of the Trailing Arm, and at that point, I will probably be able to get away with no spacers. |
Originally Posted by davidbii
(Post 1598758663)
