Build Sheet
Where would you find the build sheet on a 1994 Corvette? I have the window sticker but not the build sheet.
I've read most people find them on top of the gas tank. I've also read on here that someone found one stuffed some where in their dash.
Originally Posted by Operator2
(Post 1586262814)
Originally Posted by Retxpres
(Post 1586262856)
Ok I guess that is why I have not found it. I have never looked for it. Did not realize it was buried in to the car. I am the original owner and still love this car as much as the first day I drove her off the showroom floor.
https://store.corvettemuseum.com/ser...buildsheet.asp |
Originally Posted by WVZR-1
(Post 1586262913)
Since you're the original owner you might be interested in the NCM package that will get you a build sheet and incidentally another window sticker. All will be clean and unblemished! You might like the package.
(Post 1586262913)
https://store.corvettemuseum.com/ser...buildsheet.asp wvzr-1 way is the way to go. you dont have to get a window sticker. There is a option for just the build sheet. No need to disassemble your car to get the ones in it. Fuel tank and front frame rail. Build Sheet (Paper) - $35 Members* / $45 Non-Members |
Mine is very securely glued to the front face of the gas tank. It's not coming out without removal of the tank. Been there 24 years now so it may survive longer. LOL
Just a comment on the NCM reproduction window stickers.
I have one for the '94 6 speed that I had. The mileage figures are wrong on the NCM reproductions. My original window sticker showed 17/27 city/highway, but the NCM shows 17/24 city/highway. I have seen this same error on several other NCM ones too. If you are going to get one, make sure it will be correct when you order it. |
I don't see the requirement of "original ownership" in order to have access to these documents on the NCM site.
My '93 has two (2) build sheets, one glued and secured on the tank, which I have not touched. The 2nd one, which I retreived was located inside the frame rail, under the power steering pump reservoir. It took a lot of blood, sweat and beers to get it out (needle nose tweezers etc.) but it was intact and original. Not sure what year they began to place the build sheet in this area but it was worth the effort. :thumbs:
Originally Posted by mixalive
(Post 1586266721)
