Personalized settings.
I am having trouble reprogramming my car’s seat, mirror and steering wheel memorized settings. When I originally programmed my settings everything seemed to work properly. Then I discovered that the key fobs are numbered 1 & 2. I had originally programmed the number 1 button in the car with the number 2 key fob. Now when I take the number one key fob to the car and try and set it to the number 1 car button, it will not accept the change. Is there a way to erase the entire system and start over? Is the key fob chip that recognizes it as number 1 or 2 in the black plastic part or the metal key part? Thanks!
memory settings
Yes. Hold buttons 1&2 together until you hear a beep. Erases past memory. I had my salesman show me how to program seats and works very well. He followed the book word for word. Also, do the programing while in the cars "Settings" mode. Found on the home page of your computer screen, then "Vehicle" Good Luck
Originally Posted by e6fmf
(Post 1586288563)
Originally Posted by Weasel
(Post 1586291424)
I haven't found any marks or numbers on the fobs to indicate 1 or 2.
Originally Posted by Glen e
(Post 1586291781)
Originally Posted by Apocolips
(Post 1586291879)
Is the "chip" that the car senses in this part or the plastic part?
Had my C7 for a little more than a week, and couldn't get the memory seat to recall my position. THIS POST saved the day. My key fobs ARE numbered 1 & 2 and my wife and I had switched, not knowing there was a number system logic. Switched back and life is wonderful.... the seat recalls to #1 on the door panel.
The # of the key is IN the recess of the pull out key, shown in the red circle above. Thanks Glen e.... you saved the day. |
I found the number. Thanks. (I am a stick shift)
I have the 7 speed manual and my fobs have a 1 and a 2 in them where the photo shows.
FWIW my fobs both show the number 2. It's not likely that the numbers show here have any relevance.
Originally Posted by bgood
(Post 1586430393)
z51vett Doug |
