Fuel leak
Hey guys, I am getting ready to fire up my engine that I just put AFR 195 heads on.
I did a fuel pressure test on it to find some leaks, I found a lot, mostly all O - Rings. Now when I test it the pressure drops down and settles at around 50 ish, but I don't see any fuel leaking anywhere and I can't hear anything purging out. The pressure goes to 75 while the pump is priming then kicks down to like 60 and drops to 50 in about 15 seconds. Any ideas? I have to still adjust my FPR but after I clear up all the leaks. Thanks! |
You should list the year of your car, 75 lbs is way to much, should be low 40's at prime
Originally Posted by floridamale
(Post 1586388698)
You should list the year of your car, 75 lbs is way to much, should be low 40's. Adjust the FPR.
Never mind. I set the pressure to 60 and it stopped leaking down.
Originally Posted by DanielRicany
(Post 1586388830)
Originally Posted by MrWillys
(Post 1586389270)
Did you change the fuel pump? The stock pump is only good to about 50 psi at WOT. While it may go to 60 with no load it won't be able to maintain it when hard on it.
What about your head gasket leak??? How did that turn out??
