HELP.... steady squeel coming from FR wheel area
Ive checked.. it is not the brake pads and the rotors seem to be dead straight to the naked eye. Wheel bearing?? Any and all information greatly appreciated.
Originally Posted by KJ08
(Post 1586750638)
Thanks WW7!! Ive only had this car 5 days and it only has 65k original miles. Completely bone stock and driven quite conservatively. I'll be jacking her up first thing tom. If the wheel bearing hub assembly needs to go.. can you recommend a quality brand replacement? How much am I looking at shelling out? Thanks again.
(Post 1586750741)
Thanks. I will look them up. Going to get to the bottom of this tom!! Is it likely a bearing (or God forbid a U joint) to go out with only 65k on the ticker?? I have driven it for 4 days but this sound just started. Grrrr!!
Absolutely... will do. I'm anxious to get the wheels back off. Wish it wasnt already dark ! Lol
Some disc pads have a metal warning strip that rubs against the rotor to signify your pads need replacing. They will squeal loudly on the road and lightly as you rotate the wheel. Can be hard to see without removing the wheel and eyeballing the pads.
When a U-joint in my RR half-shaft went out it gave a clicking sound on acceleration, no squeel.
