1985 Corvette Burn Off not working for MAF
1 Attachment(s)
Hey guys I have a 1985 Corvette, and just out of curiosity I wanted to see if my burn off module was working. Turns out it isn't, as it appears.
I'm following this wiring diagram from All Data, and there is supposed to be 12 volts on the Dark Blue wire going to the MAF sensor, circuit number 994, when you shut the car off for like 2 seconds, right? Well there isn't. What are the symptoms of a bad burn off module? Thanks! |
If your car is running ok with no codes don't worry about it,
There are plenty of used or new old stock ones on ebay. The word is out that the 85 corvette burn off module is a one of and the prices have steadily risen over the years, they avarage around $40-$600 :willy: Take your pick :thumbs: Every 85 owner needs a spare. I will post the diagnostic stuff in my shop manual for testing the burn off module, when i get home from work. http://www.ebay.com/itm/Chevy-Corvette-C4-1985-Maf-Burn-Off-Module-/251518861884?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a8fb1423c&vxp=mtr http://www.ebay.com/itm/Corvette-Bosch-fuel-injectiom-MAF-Burn-off-relay-1985-14080620-Camaro-Firebird-/161289167466?pt=Motors_Car_Truck_Parts_Accessories&hash=item258d95626a&vxp=mtr http://www.ebay.com/itm/1985-C4-CORVETTE-TPI-MAF-BURN-OFF-MODULE-14080620-/181382071421?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1985%7CModel%3ACorvette&hash=item2a3b36c47d&vxp=mtr http://www.ebay.com/itm/Delco-Mass-Air-Flow-Sensor-Module-Camaro-Corvette-Firebird-Trans-Am-1985-NOS-/271423424476?pt=Vintage_Car_Truck_Parts_Accessories&fits=Year%3A1985%7CModel%3ACorvette&hash=item3f3218c7dc&vxp=mtr |
Can that cause an idle surge?
Originally Posted by DanielRicany
(Post 1586792703)
2 Attachment(s)
Ok here you go from my 85 shop manual, the correct test procedures and how the burn off module works. Note the delays before burn off, is very interesting so you can see your burn off module may be perfectly good. :thumbs:
Goes to show how valuable the shop manual is for diagnostic stuff. Attachment 48190497 Attachment 48190498 |
When I had a bad MAF burnoff relay the symptom was a rough idle. That's caused by the MAF wire getting dirty over time.
The burnoff modules were only used on '85s so they are relatively rare. |
MAf
Originally Posted by Cliff Harris
(Post 1586793506)
think you are wrong on the ""85 only" reply. My '89 has 2 burn off sensor relays on the driver's side firewall. '90 & '91 L98s were SD and so had no MAF. |
Thanks everybody for the help. It appears the burn off module is not functioning properly.
I followed the diagram and it told me that I have either a bad module or bad continuity, I tested continuity, it checked out okay, so now it says I have a bad module. Before I replace the module I wanted to test the harness and make sure that I was getting the proper voltages and grounds where I should be. I do get them but on the pink/black wire, I get like an intermittent voltage signal. I posted another thread on that, and if it turns out to be a bad connection or perfectly normal, then I will decide whether or not to replace it. Thank you everybody! |
(Post 1586796045)
Hopefully that explains your intermittent problem... |
Originally Posted by gerardvg
(Post 1586791336)
...every 85 owner needs a spare.
