CCW Wheels Experts Get In Here Please
Hi folks, I'm starting to hunt for a set of CCW Classics for my 2003 z06. I've searched dozens of posts on this forum but unfortunately very few get into the topic of backspacing/offset.
First off, here is what I am searching for: - 18x10 front / 18x11 rear - 275/35 front / 305/35 rear - 1" lip front / biggest possible lip rear - Street or Race - Any finish Now on to the questions. 1.) I want the wheels to sit flush with the fenders for that aggressive look. However sticking out beyond the fender is absolutely not an option. Given the wheel sizes I show above, what backspacing (or offset) is recommended? 2.) I like a 1" lip on the fronts. But for the rears, what is the biggest lip available for an 18x11 if we assume that the wheel may not stick past the fender? I think it would be in the 1.5-2" but need someone to confirm. Thank you! Luke |
I believe a 3" lip is the biggest you can get on an 18x11 forging... not sure on the offsets but if you call John at ccw you can get the answers you need straight from him... he has done so many wheels for this car he will know what you need right off the top of his head
Thank you for the reply about John.
I'll have to give him a ring Regarding the 3" lip, I am 99.9% sure you can't get anywhere near that on a 18x11 and still tuck |
Originally Posted by luke87gt
(Post 1586848472)
Yes with the 505s you can get the 3" lip since the spokes can curve back in.
Classics are flatter so you are more limited Do you know what ur offsets were? |
With a 305 you are going to need a high amount of offset which means not very much lip. One guy ran larger lips on classics but needed narrower tires to keep everything inside the fender.
On my last set of wheels I ran a 42 offset on an 11" wheel but I had a 275 tire so it definitely would have stuck out with 305s. |
You don't need to find an expert.
Give John a call at CCW and tell him exactly what you are looking for. I had 2 sets of CCW's on my C5 and each time I simply spoke with John and they were perfect. The last set John setup a 18x10 and 19x13 SP500's for the L5 flares. I simply told John I wanted as wide as possible but not stick out. They were flush and looked great. Call John or Chip...They are GREAT folks! :thumbs: |
(Post 1586848430)
Pm sent!
:lurk:
Be aware that often times its NOT the rim that sticks out past the fender.
Its the LARGE lip protector on the tire that sticks out. :yesnod: Something to consider when purchasing tires. :yesnod: Toque My New Bridgestone RE-11's. http://www.toquez06.com/temp/re1109.jpg My Old Continental tires. http://www.toquez06.com/temp/re1110.jpg |
Originally Posted by Toque
(Post 1586850655)
Be aware that often times its NOT the rim that sticks out past the fender. Its the LARGE lip protector on the tire that sticks out. :yesnod: Something to consider when purchasing tires. :yesnod: Toque My New Bridgestone RE-11's. My Old Continental tires.
The tire selection is certainly a valid point. Obviously the tires will play a big roll in whether there is overhang or not beyond the fender. Take for example an 18x11 rim. Guys commonly go with 295/35, 315/30, or 335/30 tire (not many street radial options outside of those sizes for an 18"). Even if that rim is flush with the fender, the 335 is 45mm wider than the 295 which means nearly a full inch more tire overhang to either side of the rim compared to the 295 tire.
Before I call John @ CCW, here are my expectations for the backspacing judging off the stock c5 z06 wheels which are close to flush. I'd venture to say that another 1/4" of front spacing on the CCWs would be great for a bit more of an aggressive look. The stock z06 wheels are: front: 17x9.5 7.38" BS (3.12" front spacing) rear: 18x10.5 8.03" BS (3.47" front spacing) If we assume another 0.25" of front spacing, I think this would be pretty close to ideal for me for a street car on the CCWs, or very close to it (I'll call John to confirm). The following splits the extra half inch of rim width to the inside and the outside equally: front: 18x10 7.63" BS (3.37" front-spacing) rear: 18x11 8.28" BS (3.72" front-spacing) EDIT: I just got off the phone with CCW and it looks like I nailed it. The sizes they recommended were: front: 18x10 7.75" BS (3.25" front-spacing) rear: 18x11 8.25" BS (3.75" front-spacing) If you want to removed the rear brake plastic then you can do an 18x11.5 8.75" BS |
And what's your lip size going to be?
Originally Posted by chassed
(Post 1586853960)
In the front with an 18x10 7.75" BS, you are limited to about 1". In the rear with an 18x11/18x11.5, you are limited to 2". There is no difference in the 11 or the 11.5 because with the 11.5 the extra 0.5" width is to the inside of the wheel, not the outside. Of course this is all assuming we are sticking with CCWs recommendations on width/backspacing to prevent the rim from sticking out beyond the fender. You can't go any larger on the lip unless you are willing to increase the front spacing (which means the wheel sticks out further beyond the fender like a dirt track car. That's not an option). I searched 100+ CCW posts and wasn't able to find this information. John @ CCW was a big help and now I know exactly what I am looking for. :flag: Only thing I forgot to ask John is how CCW measures lip since the lip size to me never looks as wide as it's advertised... |
