65 FI coupe update
6 Attachment(s)
Put the 65 FI coupe on the road for the first time last July 4th. In fact, first time driving it anywhere we went to the McKinney, TX Red, White and Boom 4th of July car show and brought a nice trophy home. Drove it a few more times sorting stuff out and quickly discovered the car had a very bad vibration. Looked all the usual places like wheels, tires, drive shaft balance etc. Vibration got worse so suspected maybe a flywheel problem so pulled transmission out and found the bearings in it were shot (it had been rebuilt) so problem somewhere upstream. Pulled engine and the shop found the previous rebuilder used mis-matched pistons, never really balanced the crank, poor torque on most bolts etc. so basically a cheap piss poor overhaul so had the engine redone with better parts at a much better shop. While that was going on and having never pulled the body off the frame, primarily because where we lived at the time had no space for such things but since we moved I now have a nice big shop/hangar and a hefty beam mounted chain hoist so decided to pull the body. Glad I did, as the original brake lines were in pretty poor shape as was the fuel line. So power washed frame and redid that, replaced all brake and fuel lines, fuel tank was good so flushed it again, painted it and put it back with a new sender, filler neck, etc. While doing all that decided that with the car out of service for a while I also pulled the gauge cluster and glove box and sent them out for restoration. As soon as I replace the transmission tunnel insulation (there was none there) and repair a small poorly repaired right inner fender (last owner piled on a bunch of fiberglass on the tire side to fix some damage, apparently from a flat tire or something, and when turning at the stops the tire rubbed so need to grind it all off and repair on the back side. Hope to have it all back together this year by the 4th of July to try again! Some pics attached showing it before this most recent episode of project creep!
Outstanding. Not only am I green with envy over your cars, I'm just as envious of your garage. Please post more pic's as you move closer to completion.
2 Attachment(s)
Originally Posted by George Washnak
(Post 1586850951)
:thumbs::cool:
I have no comment, other than EXCELLENT!
:cool: VERY NICE.................................... ...love those fuel cars
Shweeeet LITTLE garage....:cool:
Originally Posted by Dr L-88
(Post 1586851541)
Originally Posted by DZAUTO
(Post 1586851533)
Originally Posted by 66jack
(Post 1586851627)
and I thought I had toys....YOU have toys:thumbs:
Jeff - I saw you mention you were switching to 3:08's, do you still have a close ratio Muncie Trans?
Mike T. |
Originally Posted by Vet65te
(Post 1586852896)
Mike T. |
Originally Posted by steveale
(Post 1586852784)
The L-19 in the first photo isn't mine, was just storing it for someone (it was pretty neat) and the blue 67 Coupe belongs to my neighbor and I do a little work on it for him from time to time. Sorted out his headlights recently, he had them all messed up! The V35A Bonanza is mine and its a very sweet thing! All on my "bucket list" to do at some point in life, so figured it was now or never, since we ain't getting any younger and daughter finally finished grad school! |
Nice hanger set up with all the toys... The Bird Dog is on my bucket list. I had a 1948 Globe Swift with a HIO-360... sold that to buy a K Model Bonanza V-35. Now the Vette.
Originally Posted by VetteRed1965
(Post 1586855513)
Originally Posted by Texaspilot180
(Post 1586850094)
(Post 1586852482)
Thanks Rex - that nice rear differential you sold me is properly in place and properly lubed and ready! Anxious to try driving it this year with 3:08 gears, hopefully that will reduce the highway revs and the noise that generated just a bit for the wife. She didn't care for the screaming loud version, but I'm hoping she will tolerate a toned down version rumbling down the highway in cruise! Jeff
Originally Posted by PierreOlivier
(Post 1586858494)
Really like the pulley system and alternator on the engine - where did you get them?
Originally Posted by sshort67
(Post 1586858949)
Forty years ago we were looking for 4.11's and junking 3.08's. Could not give away the removed differentials. Now I save almost every removed/updated part. I draw the line at broken bolts, do not have enough storage. Good luck with the wife, we waited till our hearing had gone south "what did you say"-"huh".
