NEW 6 channel Focal and ARC amps now available!
For those of you wanting to run a bit more power than the normal 5 channel amps then we have something for you!
Arc and Focal have a couple real nice options for amps to power your entire system with more than enough power! Here is some info below on each. Just call us for ordering info and package deals on the amps! 608 568 3011 or email to dennis@doubledmods.com Focal FPD 900.6 http://i45.photobucket.com/albums/f6...n050/focl6.jpg Full Range Class D Advantages: Very small size for power output Can be used in 3, 4, 5 & 6 channel modes High-level input, compatible with OEM Stereo Easily accessible settings Remote sub control Invisible mounting bracket Highest level of crossover flexibility Specifications: Power into 4 Ohms 6x150W rms Power into 2Ohms 4×200 + 2x275W rms Bridged mode into 4 Ohms 2×400 + 1x500W rms Bridged mode into 2 Ohms (Ch 5&6 only) 1x600W rms Frequency response 5Hz–30kHz Signal/noise ratio >101dB (A) Adjustable gain 200mV + 10V Dimensions(HxLxD): 2 x 13-7/8 x 7-3/8in (50x351x186mm) Protections Short-circuit, thermal overload, polarity reversal, DC ARC Audio XDi 1200.6 http://i45.photobucket.com/albums/f6...an050/arc6.jpg SPECIFICATIONS↓ Download XDiV2 Amplifier Manual Download Product Manual Here 4 Channels @ 4ohms (Ch 1-4) 150 Watts 4 Channels @ 2 ohms (Ch 1-4) 150 Watts 2 Channels @ 4 ohms (Ch 1-4 Bridged) 300 Watts 2 Channels @ 4 ohms (Ch 5-6) 150 Watts 2 Channels @ 2 ohms (Ch 5-6) 300 Watts 1 Channel @ 4 ohms (Ch 5-6 Bridged) 600 Watts Frequency Response 20Hz - 20kHz Crossover Range (Ch 1-2) 50Hz - 550Hz (x10 500Hz - 5500kHz LP only) Crossover Range (Ch 3-4) 50Hz - 550Hz (x10 500Hz - 5500kHz LP only) Crossover Range (Ch 5-6) 50Hz - 550Hz (x10 500Hz - 5500kHz LP only) BP capable Yes (Ch 1-2 & 5-6) Bass Boost 0-12dB @ 45Hz (Channel 5-6 only) Remote Level Control Included Yes - LP Ch. 5-6 Only Input Sensitivity (Low) 200mV - 3.5V Fuse 3 x 30 amp Cosmetic Trim XDi Level 2 Dimensions 13.0"(L) x 6.268"(W) x 2.162"(H) |
Dennis, please give me a call. Need to speak to you.
Ive used the Arc xdiv2 1200.6 in an install, really good sounding, flexible and powerful amp.
