How To Upload Pictures
1) Click on the Insert Image icon https://www.corvetteforum.com/forums...nsertimage.gif as shown in the illustration below:
https://cimg2.ibsrv.net/gimg/www.cor...f752ecb734.jpg 2) The Upload Manager appears. Select Browse Your Device if your pictures are stored on your computer or select My Albums button if your pictures are in your CorvetteForum's album. https://cimg4.ibsrv.net/gimg/www.cor...1d1db3a639.jpg 3) Locate the picture on your computer. Left-click on the file and then use Open button to begin the Upload. NOTE: You may select multiple pictures by holding CTRL key and then selecting each file. Once finished selecting, use Open button to begin the Upload. You may also drag and drop files between windows. NOTE: Adding too many pictures at one time may cause long delays and/or failure of uploading depending upon network (your ISP to CorvetteForum) conditions. https://cimg6.ibsrv.net/gimg/www.cor...45c40d5c6c.jpg 4) The picture will immediately upload to CorvetteForum and a thumbnail will display once finished. You can then type a description to appear below the picture, which will appear directly below the picture in your post, you may re-order the display of the pictures, delete the pictures, or continue by clicking the Upload button as shown in the illustration below: https://cimg5.ibsrv.net/gimg/www.cor...fd70b1b5ec.jpg 5) The [IMG] tags, which will display the pictures you've uploaded, will appear for each picture you've uploaded. The [I] tags, which will display any description you've typed, will display below each picture. You may add any text below or above these tags and/or Smilies. When you're ready to post your message, click the Submit New Thread button. |
To avoid cluttering up this thread:
If you have a technical issue with posting pictures, please post a new thread in the Help forum using the following link: http://forums.corvetteforum.com/newt...newthread&f=31 If you want to TEST the new picture posting, please use the Testing forum: http://forums.corvetteforum.com/testing-68/ Thanks! |
