C5 Flasher fix from Corvette enhancements.
Great product. 10 min install. if your having flasher fail issues. this is a 70$ fix .
http://www.corvette-enhancements.com/c5_flasher_fix.php |
$10 and 15 minutes
two prong flasher unit, cut OEM feed (Pink) and output (Purple) wires going up into the Hazard switch and installed female spade lugs unto the wire ends. Connected them to the flasher unit https://cimg6.ibsrv.net/gimg/www.cor...a80fc474b4.jpg https://cimg2.ibsrv.net/gimg/www.cor...ce0dab56c8.jpg https://cimg9.ibsrv.net/gimg/www.cor...30c20490e0.jpg https://cimg9.ibsrv.net/gimg/www.cor...73d4eab055.jpg https://cimg8.ibsrv.net/gimg/www.cor...1cca992fe5.jpg |
[QUOTE=pewter99;1587219881]$10 and 15 minutes
two prong flasher unit, cut OEM feed (Pink) and output (Purple) wires going up into the Hazard switch and installed female spade lugs unto the wire ends. Connected them to the flasher unit If I am correct, you now do not have the "Hazard" feature that works? |
[QUOTE=dadaroo;1587224096]
Originally Posted by pewter99
(Post 1587219881)
$10 and 15 minutes
If with your "fix" you still have the Hazard function work, then your Hazard flasher IS working.
If you were having a turn signal issue then it was with the switch contacts where the pink wire feeds the flasher and not the actual flasher unit. I have proven that several times. I think the reason people can exercise the Hazard switch and get their turn signals to work is that the contacts are bad and not the flasher. I doubt the flasher is bad in most cases but "it" gets blamed. http://i1250.photobucket.com/albums/...991/img115.jpg |
OK guys, I have relooked at the circuit and it appears the Hazards will function since the new flasher will "back feed". However, it will not do it as designed. You must have the ignition ON. It should not work otherwise.
Your humble contributor. Mr. Sam |
so witch contacts do I need to clean?have cleaned the flasher unit with contact
cleaner! |
Originally Posted by dadaroo
(Post 1587232132)
Your humble contributor. Mr. Sam The hazard on position of the switch uses the orange for power and the brn, lt blu and dk blu wires to feed the signal lamps. The pnk and ppl wires aren't used at all in the hazard position. Look inside the hazard switch box. With those contacts switched to the right (right is the hazard on position) the pnk wire is not connected. Look at the signal indicator switch. With it in the center position, the ppl wire isn't connected. |
all I can tell you is the flashers didn't work....fking with the hazard switch got them to work occasionally....but that wasn't feasible everytime you needed them to work.....I did the above fix and now everything works everytime and has worked fine for almost a year.
YMMV :cheers: |
(Post 1587235369)
all I can tell you is the flashers didn't work....fking with the hazard switch got them to work occasionally....but that wasn't feasible everytime you needed them to work.....I did the above fix and now everything works everytime and has worked fine for almost a year. YMMV :cheers:
Originally Posted by lionelhutz
(Post 1587234400)
It will work fine as long as the flasher and contacts in the hazard switch still work well enough to light the bulbs. You neither require the key on or the new flasher to back feed anything.
Also if you have LED hyperflash Pewter99's fix will work too, you just need to chose a relay similar to used in the OPs. |
If the hazard flasher has failed then the bypass won't fix the hazards and they still won't work key on or off.
:iagree:
That was what I thought originally. Then, I got stupid somehow when he had hazard flashing and thought he had "Tee'd" into the purple wire. He did not do that. |
Yeah, my led hyper flash is getting more frequent, and now sometimes the turn signals won't flash at all. When this happens, I can just tap the hazards on/off for a second then the signals work again. So do I understand correctly that the OP's $70 fix will remediate both issues?
Thanks |
Originally Posted by c4_4ya
(Post 1587259132)
Thanks |
I just replaced my hazard switch with an oem one and while it wasn't exactly fun, it took me less than 30 minutes. Follow the instructions in this thread: http://forums.corvetteforum.com/c5-t...placement.html
Originally Posted by TitanZ06
(Post 1587219524)
http://www.corvette-enhancements.com/c5_flasher_fix.php Now it falls on me. Does anyone have a pic of the plug location or instructions in case it's harder to find than I think................:eek: Thanks in advance, Randy |
I sent you a PM.
Question for you guys who've added the 2 prong relay. I did this and it has cured the hyper flash issue w/ turn signals however the 4 ways will still hyper flash UNLESS I have a turn signal on. Any input on that? I'm going to check the wiring diagrams but it seems people have successfully done what I'm attempting so it is probably some oddity.
I used an EFL-2 LED flasher. Thanks Dave |
When you do that the original Hazard flasher is still in the circuit for Hazards.
https://cimg5.ibsrv.net/gimg/www.cor...6d92651b4d.jpg |
