New From TKO-C7 Blockit Lay In Sound Deadening System - Installs In Seconds
Quiet Down Your C7 Stingray & Z06’s Interior In Seconds!! The BLOCKIT "Quick & Quiet" mats simply lie right over your existing carpet! RIGHT NOW ON SALE! https://cimg4.ibsrv.net/gimg/www.cor...4d1c007d40.jpg https://cimg0.ibsrv.net/gimg/www.cor...681c492236.jpg IF you’re looking to take the edge off some irritating noises that still leaks into the C7 stingray or Z06's cabin, check out the BLOCKIT "Quick & Quiet" System. The 3 piece Quick & Quiet BLOCKIT system absorbs and suppresses unpleasant sounds. This is NOT a single layered mat. The Blockit Quick & Quick is made up of 4 unique layers of actual sound proofing material. Its 1" thick! (But it can easily be compressed for any aftermarket cargo trays..etc, ) It’s perfect for taking that annoying edge off tire/ road noise (this applies especially to those that live in certain states where the roads make the tires roar) & some aftermarket exhausts. Makes a nice noticeable difference. NO need to rip out your carpet & interior! The precision pre cut BLOCKIT sound deadening system lies right over your carpet. One mat for behind each seat. One mat of the cargo area. Rather then carve out a big area to accommodate the cargo hoops, we choose to have small precise cut outs which allows there to be more material to maximize sound proofing. https://cimg6.ibsrv.net/gimg/www.cor...30566901e8.jpg The durable UV protected top layer looks great and allows you to still use your cargo area. Feel free to place an aftermarket cargo mat on top! Made in the USA! * Reduce Interior Noise In Seconds * Takes The Edge Off Tire/Road Noise & Some Aftermarket Exhausts. * No Ripping Up Your Carpet/Interior * Pre - Cut & Lays Right Over Your Factory Carpet. Fits your Stingray or Z06 * The Blockit is a 3 Piece System - (1 piece for behind each seat. 1 large piece for the cargo area/trunk for the convertible). * The Blockit uses 4 layers of REAL acoustical material. (This is NOT a simple foam layer with foil!) * The top black vinyl layer is UV protected. Looks great & its durable so you can still use your cargo & truck area. * The C7 Blockit has custom "cut outs" for the coupes cargo hooks! * The product is made in the USA * Follows Automotive guidelines & manufactured under strict ISO 9001-2008 standards! * The Blockit also acts as a heat barrier. It helps prevent some heat that comes up through the cargo area. Get It Now At A Forum Special Price! ★Check it out & securely order 24/7 online:http://store.tkoperformance.com/20c7blsodesy.html ________________________________________ ___ A huge hit when it was released for the C6! Below is a list of some threads from many satisfied customers/forum members. Within theses threads you will find a ton of others posting their positive results with the Blockit too. http://forums.corvetteforum.com/c6-c...ation-mat.html http://forums.corvetteforum.com/c6-c...e-product.html http://forums.corvetteforum.com/c6-c...ning-mats.html http://forums.corvetteforum.com/c6-c...d-deadner.html http://forums.corvetteforum.com/c6-c...irst-ride.html http://forums.corvetteforum.com/c6-c...irst-ride.html http://forums.corvetteforum.com/c6-c...rformance.html http://forums.corvetteforum.com/c6-c...ning-mats.html http://forums.corvetteforum.com/c6-c...post1573973170 http://forums.corvetteforum.com/c6-c...-block-it.html Get It Now At A Forum Special Price! ★Check it out & securely order 24/7 online:http://store.tkoperformance.com/20c7blsodesy.html Feel free to call 1800 778 9898 Mon-Fri 9-4:30 est. Thank you checking our post out! |
:cheers:
PM price please.
Thank you for the orders!
Blockits are in stock. Ready to roll. All orders shipped yesterday. :thumbs: |
Great! I loved it enough in my C6Z that I bought it for the C7!
Since my Stingray will be used for cruising and long trips I will want to investigate this. Seems like a must have.
Originally Posted by rpoz06
(Post 1587390020)
Thank you for your business! :cheers: Ed
Originally Posted by AFVETTE
(Post 1587390095)
:thumbs:
Do you have a package for the vert?
*All orders placed Over the weekend are leaving today! :thumbs:
*New pictures will be coming soon.. :thumbs:
Originally Posted by Silverblue
(Post 1587405158)
:cheers:
I can't tell from your pictures what the top surface looks like. Is it carpeted so Velcro will still stick to it? Does the color match the standard stock Corvette interior black?
If not, do any of our home hobbyist types know how hard it is to lift the carpet, put this Blockit under it, and reinstall the factory carpet back on top so it stays securely in place without shifting? Thanks much! |
Originally Posted by CaryKen
(Post 1587431578)
If not, do any of our home hobbyist types know how hard it is to lift the carpet, put this Blockit under it, and reinstall the factory carpet back on top so it stays securely in place without shifting? Thanks much! Making the top layer "carpet" (which we thought about doing in the beginning..) costs a ton of money and would turn most away. When we use to demonstrate it (in a vehicle), the first thing we heard was "wow it looks nice".... As for placing it under the carpet... Some did it with the C6. Some areas of the carpet would simply come right up. However I have not tried it yet on the C7. Thank you for your interest. Feel free to contact us if you have any other questions :cheers: |
:cheers:
Is Blockit material available in sheet form or in kits for other brands of cars? A link would be appreciated.
It looks like the name is used on a variety of products that have nothing to do with sound absorption or cars, so my searches haven't turned up anything helpful. |
Received my order yesterday and immediately installed. Took only a few minutes to install and looks good. Wife and I took it out on one of the notorious noisy roads here in Texas and here is our opinion. I was hoping for more noise reduction. It helps but certainly is not a cure all. Being over 6ft 2in I regret losing leg space as a result of the two pieces that go behind the seat backs. To me the quiet roads are even quieter but not much help on the rough noisy ones.
All orders placed over the weekend are shipping today.
Thank you |
Having had Blockit in my Z06 - I thought it did a great job reducing noise so I added it to the C7 - Z51.
It arrived packaged well. Easy install with a precise fit. I was able to use the rings and shade. I found it able to make a nice noise reduction on all surfaces around Little Rock including interstate and different road surfaces including concrete and asphalt. I'm very happy with the product! |
:thumbs:
:cheers:
