GCA Borla Exhaust Enhancer Plate
2 Attachment(s)
Finally! A simple exhaust enhancer plate that works with a little fabrication on my 2008 Convertible. Modified for GCA/Borla 4" welded tip exhaust. The bolts on the exhaust hanger and the plate line up perfectly.
I started with part #48641 from Ecklers. Bent the mounting to set back about an inch and used a grinder to cut the stainless to fit between center pipes. I wouldn't try it with the plate containing flags and "corvette" lettering. You may be into the lettering with the cuts. Hope this helps somebody else. (Sorry about the sideways pic but you get the idea.) |
