1991 Corvette M6 w/FAST XFI efi system installed buy before I part it out
The original ad is below. I'm stealing the new radio out of this and putting it in my wife's car. While the dash is out, I'm considering breaking it all down into a pile of parts and selling off everything. This is a complete running car (still needs some tuning work, but it runs decent....I drove it to work all through October in downtown Columbus, OH traffic). I'd love to sell it complete. I'm adding this information at the top because there's another thread here where someone is parting out a C4 and someone asked "looks like a decent car, why did you part it out?". I'd like to avoid that question. Right now, I can't seem to sell it and it's likely worth more in parts. If someone shows up with the right amount of cash, I'll help them load it (2 sets of wheels, spare parts, a pile of brake pads and all). If not, I'm looking at getting rid of all of it in pieces in an effort to get the cash out of it. It is a complete and running car (new sun visors, new center console lid, complete interior, new AC lines and PS lines, PS pump and Alternator, etc).
I'll probably give it a few more weeks and then I should have time to tear it apart (I just had surgery on my elbow a couple weeks ago and I'm just getting to where I'm ready to play in the garage). I've decided to sell my 1991 Corvette M6. This is going to be a little long, but here's the scoop... I had a 1992 Z28 autocross car and I decided I wanted a street car. I pulled the engine out of the Z28 (approximately 1,200 miles on it since it was built) and bought a Corvette. I put a set of Trick Flow 175 heads on it and a TPIS Miniram II as well as a TPIS throttle body and did a complete tear down and refresh before putting it in the Corvette (rod/main bearings, had the crank polished, new cam bearings, all gaskets and seals, new heads, new intake, new throttle body). I bought a Canton road race pan for it, stainless works long tube headers and a Dewitt radiator and started putting it together. The transmission was converted to crash through and a Hurst shifter was installed. I also ordered all the weather stripping for it and changed some (the rest is in a box) as I had time. It also has a new center console lid and new sun visors. The heads, intake, clutch, flywheel and distributor have about 85 miles on them, the throttle body and injectors are less than that and I installed the Borla kit after the rest was done. I've paid for two proms from two reputable places and eventually gave up and installed a full FAST XFI 2.05 EFI system. This took care of things and the car runs quite well now. I have a pile of money in this car, I'm asking far less than I have in it. I'm selling the car and the collection of parts I have for it as a lot. It's red with black leather and has 118 k miles on the chassis and a 6 speed with 3.45 gears (dual power seats, electronic climate controls). I'll save time and just start a parts list: 350 bored .020 over with splayed main caps and two bolt studs (and a billet front bearing cap on the #1 main) Forged crank (ZZ3 crank) Lunati Street Race rods (5.7") with floating pins. KB Signature Series 12cc dished pistons Speed Pro plasma moly file fit rings zero decked, torque plate honed and line bored. Clevite bearings Melling oil pump Cloyes double roller chain Comp cams 220/230 .510/.510 cam (114 lobe separation) Comp roller lifters Comp pushrods Comp Cams chromoly 1.52 roller rockers (7/16" studs) Canton 7 quart road race oil pan (5 trap door baffles) Moroso aluminum valve covers with a screw on cap TIG welded on Trick flow 175 heads (10.49:1 counting decking, head gaskets and all) ARP 7/16" rocker studs ARP head bolts ARP header studs ARP oil pan, timing cover, etc bolts ARP Pro series flywheel bolts ARP harmonic balancer bolt Jegs billet aluminum distributor hold down TPIS Miniram II (1205 gasket) Accell 36 lb/hr injectors TPIS 58mm throttle body Davis Unified ignition HEI distributor MSD gear reduction starter MSD plug wires ATI lightweight aluminum Superdamper (3 ring, road race version with aluminum shell) Aluminum adjustable timing pointer Stainless works long tube headers (with air system removed and the holes TIG welded closed) Cat delete pipe (bolt in using a band clamp on the front and the stock ball and socket rear flange) Borla cat back DeWitt 1.5" fabricated aluminum radiator Hurst shifter (gearbox was converted to crash through) Hurst 6 speed shift knob (black with white numbers/markings) Walboro 255 lph fuel pump (Racetronix kit) Goodyear hoses New power steering hoses and remanufactured pump Alternator was replaced last month (reman from a parts store) 2 piece under drive pulley set Edelbrock water pump Fidanza aluminum flywheel Centerforce dual friction clutch New 275/40-17 Sumitomo summer tires (40 miles on them) 2 total sets of sawblades J55 brakes (on the car) Spare drive axles (rear, aluminum) 4 U joints for the rear axles (still in boxes) New U joints in the driveshaft Non crash through shift shaft from the ZF gearbox Brembo "Sport" brake pads (on the car, and a set new in the box) Metal Master brake pads (in a box) New strap kit for mounting the rear axle U joints (still in a box) Monroe Sensatrac shocks (40 miles on those, the shocks on the car had lost their oil and these were put on as a temporary improvement until I got it tuned) Accell 36 lb injectors A box of weather stripping (the stuff I haven't installed) Both tops (tinted and body color) JVC in dash DVD player with hands free/bluetooth and Rockford rear speakers (fronts are in a box, I never got time to install those) AC has been converted to R134 (but I was planning to change it back to R12). I'm sure there's more and I'll go through the garage and update this. I'd rather find someone who wants to finish the tuning (it runs great, there's always some little things to do) and enjoy it instead of parting it out. So, in a nutshell, if you like tuning these cars and want a car with a lot of nice stuff in it....look me up. Pics on request. And I own the F-body road race autocross forums (www.frrax.com), there is a thread on there about the Camaro (that I had this engine in) and a thread about building the Corvette with some pics where you can see what's where and what's in the car, etc. There are some pics of the FAST install in this thread starting on May 1st. https://www.corvetteforum.com/forums...thout-one.html Located on the west side of Columbus, OH. trackbird (at) gmail dot com $14,500 |
https://cimg7.ibsrv.net/gimg/www.cor...0fe2c17062.jpg
helping a member out, he emailed me a bunch of pics of his 91 vette, just uploading them for him. mainly learning for myself for the future. but enjoy the pics. not all of them, but a sampling of what he sent to me. good luck! enjoy |
The FAST install is completed and the car is making good power (flooring it in first will obliterate the tires at any speed). I'm looking at a 2013 C6 and I don't have room for both cars.
Pics on request. Feel free to contact me for any additional info. Thanks! |
Offers? I'm guessing it's worth more in pieces, but I hate to tear it apart.
$11,000
The Borla kit has been swapped out for a Magnaflow kit about 2 months ago (the Borla kit was loose and the mufflers wouldn't stay lined up so I replaced it). I've been driving it to work. It has all 4 speakers installed and it runs well. Full disclosure, the oil pan seems to drip a bit of oil (seems to be a Canton pan issue). Includes a spare set of sawblades with old race tires (from my days autocrossing a 4th gen Camaro), the rest of the weatherstripping, both tops, rear u joints (for the axles), spare rear axle shafts and an assortment of other odds and ends I gathered up for the car. |
$10,000 firm
$9,999.99
See updates at the top of the first post. I'm going to start listing some of the leftover parts in another thread and selling off the spares. |
