Oil cap adapter
So i finished my remote turbo build however I have a bad oil leak right where my oil return goes through my oil cap. Is it possible to purchase a oil cap or a set of valve covers that has a -10an flared male adapter built into it?
This is the closest thing I found which according to the picture it looks like it could fit. Has any one tried this part on a 94 corvette LT1
http://www.hawksthirdgenparts.com/pr...N-Fitting.html |
Originally Posted by Impala Balko
(Post 1587431520)
http://www.hawksthirdgenparts.com/pr...N-Fitting.html Earlier LT covers and some aftermarket covers use a nearly "fully threaded" cover. I believe all '92 covers were like these. |
So i ordered that part it appears that it should fit even though it's for LS motors
(Post 1587440915)
You will be fine! |
Originally Posted by WVZR-1
(Post 1587441568)
There is no difference in the LT/LS oil cap retention. The vendor is likely an LS orientated reseller and that's his only concern.
You will be fine! |
