FS BTO 2004R Level 3 Trans Atlanta GA
Transmission was purchased new from Bowtie Overdrives in 2004. I swapped over to a manual transmission in 2007. This transmission has under 5000 miles on it. I also have a 2800 Extreme Duty lock up converter for it. It was never raced and an aux. fan powered oil cooler was also used.
Original cost: Trans: 1,325.00 TC: 569:00 Asking: Trans: 800.00 will include throttle cable TC: 200.00 Cast aluminum deep oil pan: 50.00 For local pickup only. |
Originally Posted by KJL
(Post 1587462026)
Transmission was purchased new from Bowtie Overdrives in 2004. I swapped over to a manual transmission in 2007. This transmission has under 5000 miles on it. I also have a 2800 Extreme Duty lock up converter for it. The day before I removed it, i noticed the torque converter was having issues with the lock up feature. I did not have time to investigate so not sure what the problem was. It was never raced and an aux. fan powered oil cooler was also used.
Original cost: Trans: 1,325.00 TC: 569:00 Asking: Trans: 800.00 will include throttle cable TC: 200 Cast aluminum deep oil pan: 50.00 For local pickup only. |
Originally Posted by JagNorb
(Post 1587462422)
Do you have the transmission part number transposed? I thought it was 200R4.
Same transmission regardless of name.
It's suppose to be 2004R but many people call them 200R4 because of the popular 700R4 and mixing them up. |
I'm interested in the pan for $50, what will shipping be to 60051?
Originally Posted by '75
(Post 1587619001)
Exactly what I am looking for, wish you were closer to St Louis, MO!
