Fbody front wheel bearing hubs on C4
This may have been covered before but I haven't seen a specific thread with pictures so here you go...
After looking around for 1996 C4 Corvette front wheel hubs I found they were quite expensive. Anywho, in the depths of the interwebz I found a thread about using Fbody hubs on a C4. To note I don't know if they work on any other models other than 91-96 C4 and more specifically I am only knowledgeable on the 96. The only real difference is the Fbody hub bolt holes are threaded. Another note is I am not running ABS, so I can't make a claim on whether the reluctor ring has the same teeth or if the plug is identical. I'm just some guy that happened to buy some 2002 Fbody Moog front wheel bearing hubs and install them. My car is a 1963 Grand Sport with a C4 suspension and a lot of other custom goodies. Im running 315/30/18s up front and 335/30/18s in the rear, so if the bearings are crap I will find out real quick. The car. http://i418.photobucket.com/albums/p...pspyfjbuug.jpg http://i418.photobucket.com/albums/p...pspsc6efoy.jpg http://i418.photobucket.com/albums/p...pshrphzjih.jpg http://i418.photobucket.com/albums/p...psxt48igad.jpg |
I wonder if a brake bracket for a f-body would also fit.
EDIT although I tend to think those aftermarket brackets place the caliper in the same place as the factory c4 brackets. |
Very nice, thanks for the info.
I'll try to lock it into the memory bank. |
Useful thread! I believe it was Redls1gto's post on another forum that have me the idea.
https://www.corvetteforum.com/c4-general-discussion/2579676-front-wheel-bearings-wear-condition.html?styleid=140 |
That information is pretty widely known and as you mentioned it's for '91+ spindles only. As for the 'construction' comparison, I don't believe I've ever seen that posted. I've never looked either so it may well be out there. Mine is a '90 and the fit is a 'no go'.
Originally Posted by chevyowner
(Post 1587502253)
Is the hub register taller or is that just the difference between new and dirty? I'd prefer a taller register myself.
Originally Posted by WVZR-1
(Post 1587502308)
NO!! It also seems that they are a copy of what is already there on the c4. They are not sold by a sponsor so I cant post a link to them, |
