Replacing Z51 rotors & pads with oem or aftermarket
Just curious who has replaced the original Z51 set up with oem or aftermarket rotors & pads,if replaced with aftermarket parts do you have an regrets ?
Fwiw my car is 05 46k with Z51 options,also never autocross my car or driven on a 1/4 or 1/8 mile tracks. |
I replaced my pads last year with ceramics by Akebono on my Z51.....No to Low brake dust and no dreaded brake squeal. :thumbs:
Originally Posted by crusher1
(Post 1587503519)
What type of condition were the rotors in..uneven wear or gouging,and how many miles did you have before you replaced them..I guess mileage would be irrelevant if you tracked or raced the car. |
Originally Posted by Johnny Utah
(Post 1587503179)
AC Delco Ceramics.. all four corners for under $100 on popular shopping sites. Best street pads IMO.... Your rotors are probably fine, but just buy OEM unless you want to upgrade performance or appearance. I use DBA T4 Club Spec as an "affordable" upgrade for my dual use car.. I hit the track about 6-8 times per season. Go through front rotors once a season.. Rears are good for two years at least... I use Carbotech track pads for track days (XP12 AND XP10).. You wouldn't want to use this type pad on the street.. WAY too much noise and dust, but boy do they bite when threshold breaking at the track.
(Post 1587503550)
Thanks!
What type of condition were the rotors in..uneven wear or gouging,and how many miles did you have before you replaced them..I guess mileage would be irrelevant if you tracked or raced the car. If you do decide to go with them: Here are the part number(s) for front and rears: Akebono ACT731 ProACT Ultra-Premium Ceramic Brake Pad Set & Akebono ACT732 ProACT Ultra-Premium Ceramic Brake Pad Set |
I went cheap and "no ragrets"
AC Delco Ceramic Brake pads GM P/N fronts-88909667 Rears- 88909668 Brakeperformance,com Drilled rotors: Front: #DB-62086 Rear:#DB-62096 |
