Update on Cooling Fan Connector Melting
Have there been any "new fixes" or methodology to correct this ongoing problem with the melting connector?
Better connectors.....where to purchase......without having to buy the whole fan shroud assembly? |
Many on here have just cut the connector and soldered the wires directly..I would certainly do this before buying some expensive part. In the unlikely event that you need to disassemble at some point, they can be unsoldered.:thumbs:
Originally Posted by cclive
(Post 1587610240)
Connector
I just wired it up eliminating the crappy electrical connector and the fan is running..........thanks for the advise.
Originally Posted by secrt0007agt
(Post 1587612533)
Hard wire it n avoid a repeat
where is said connector located?
Connector
On the cooling fan shroud just above the cooling fan module.
Originally Posted by tennblkc6
(Post 1587619675)
(Post 1587619675)
(Post 1587619732)
Passenger side half way up the shroud. Easier to get it from underneath. Well was for mine as the blower is in the way. |
For those who have done this "mod," is this the dreaded connector:
http://i99.photobucket.com/albums/l3...d/DSCF1026.jpg Coming from the power side, red/black, black, and green wires-->connector-->red, black, and red wires going to fan control module I think it may be the one everyone's referring to, but mine may be moved from the stock location since I had Spal dual fans installed with the OEM radiator. |
Originally Posted by fastdoc71
(Post 1587663175)
Coming from the power side, red/black, black, and green wires-->connector-->red, black, and red wires going to fan control module I think it may be the one everyone's referring to, but mine may be moved from the stock location since I had Spal dual fans installed with the OEM radiator. https://cimg3.ibsrv.net/gimg/www.cor...50801a23cf.jpg |
