Chasing my last water leak before interior goes in
Long storry short, I am in the final stages of my frame off resortation that has taken me about 16 years to complete.
I have a water leak on my 72 Coupe that is driving me nuts. The water is running down the door jamb area (rear of the door to quarter) and running in at the corner of the sill plate and interior quarter trim. The water basically pools where the outer rearward seat mounting bracket botls to the floor. I saw some trim moldings at the base of the door jamb in another post which my vette does not have. See the post below. http://forums.corvetteforum.com/c3-p...-windlace.html Is that trim mld at a 45 degree angle to deflect water? Any ideas or suggestions would be greatly appreciated. Thanks!! |
:lurk:
Yup, that's what my 72 did too I added a bead of seal sealer (dumdum) under the very back of the sill plate and let is squish out to prevent the water from making it into the interior. It still ran onto the sill plate and pooled there. Mine didn't have those pieces shown on Alan's 71 and I don't recall finding them in the AIM so eventually I installed a set of the diverters that they used on the 74 and up cars (again, can't even spell NCRS) |
If Alan drops in, where are those pieces in the 71 AIM?
M |
Hi,
The water diverter is called out as a 'strip' with 2 pop rivets in the 71 AIM in UPC 1 Bolt/Weld, Sheet B9, Item 13. It's a very busy sheet so they're easy to miss. They're available in reproduction but are pretty $$. Regards, Alan |
Originally Posted by Alan 71
(Post 1587683094)
Hi,
The water diverter is called out as a 'strip' with 2 pop rivets in the 71 AIM in UPC 1 Bolt/Weld, Sheet B9, Item 13. It's a very busy sheet so they're easy to miss. They're available in reproduction but are pretty $$. Regards, Alan M |
Originally Posted by Mooser
(Post 1587683153)
Any chance that was a 3974085 ?
M Hope this helps. |
Originally Posted by 70Yellowbird
(Post 1587684080)
My '70 AIM has 3974085 for the LH Water Deflection Strip, and 3974086 for the RH Water Deflection Strip.
Hope this helps. BlownZ51, I don't know when your car was built but we might not have ever got them M |
(Post 1587684202)
That's what I figured, they were deleted in early 72 according to the AIM
Hi,
Here's the fiberglass strip pop riveted in place. The later one is a combination metal/rubber diverter. Regards, Alan Paragon has both styles. 12689k and 5854/5853 http://i218.photobucket.com/albums/c...DSC_0228-1.jpg |
(Post 1587686689)
Hi,
I wonder when (and as always, why) they dropped them in 72 and 73. The date on the AIM was Feb 11, 72. I can only guess there was a NIEO out to remove it some time before the AIM was updated so Might have even affected later 71's
Here's what the 74+ style looks like http://i1099.photobucket.com/albums/...psd583a8f6.jpg It actually attached under the sill plate edge and has a rubber lip to help catch the water. M |
(Post 1587689298)
Originally Posted by BlownZ51
(Post 1587705678)
Did you install these on your 72? Just wondering if you were able to make them fit. I'm assuming that you just drill the holes to mount them under the sill plates. Do they clear the doors ok as well?
Look away Alan !!! Here's how they attached under the sill plates http://i1099.photobucket.com/albums/...psd2594413.jpg http://i1099.photobucket.com/albums/...ps5f9f60a7.jpg Two rivets into the flat under the sills. Then I run a string of butyl along the corner as insurance. HIH M |
(Post 1587705843)
Yeah those are on my 72. been there for years, never had a water problem after installing them, never had any issues on the doors, I'd say lots of room.
Look away Alan !!! Here's how they attached under the sill plates http://i1099.photobucket.com/albums/...psd2594413.jpg http://i1099.photobucket.com/albums/...ps5f9f60a7.jpg Two rivets into the flat under the sills. Then I run a string of butyl along the corner as insurance. HIH M As long as it keeps my interior dry I am happy! It looks nice and clean with the sill plates installed. |
