1980 interior questions
Fellow late C3 owners. I'm doing some interior and door panel work on my 1980 (I swear Bubba didn't use the same screw twice in there...), and had a few questions.
Is this molded area on the left driver footwell just structural? Is it supposed to be carpeted over or exposed? http://i1265.photobucket.com/albums/...pshm9jjtcq.jpg What is this part directly under the steering column? Not for the courtesy light is it? http://i1265.photobucket.com/albums/...psjtxos8bi.jpg Finally, on the kickpanels, is the carpet supposed to go down all the way to cover the bottom trim area pointed to or should the lower plastic margin be exposed? http://i1265.photobucket.com/albums/...psppntjciy.jpg Thanks for any knowledge/assistance offered. :thumbs: |
One more question. Under my carpet (which has the multicolor thread felt underlayment, there is an additional layer- it's sort of black, rubbery material bonded to more of the same underlayment felt. Is this stock? Looks like the PO had a heater core leak, so I may be in for some nasty surprises when I pull all this up...
http://i1265.photobucket.com/albums/...psdfbbqclw.jpg |
Tarry mat bonded to the Jute or compressed dryer lint as I call it is original.
New replacement carpet I'm laying down has the jute bonded to it already. I'll check the original carpet tomorrow and see if it has jute bonded to it or if it just layed on the tarry sound deadener I dont know what the part under the column is. Every thing at the driver footwell gets covered in carpet. Kick panels get fully covered |
That thick 'tar-paper' is from the factory and is meant as a sound-deadener wherever you find it. (usually on the floor/firewall areas)
Originally Posted by SciVette
(Post 1587773532)
...Is this molded area on the left driver footwell just structural?...
... Is it supposed to be carpeted over or exposed?... ...What is this part directly under the steering column? Not for the courtesy light is it?... ...on the kickpanels, is the carpet supposed to go down all the way to cover the bottom trim area pointed to or should the lower plastic margin be exposed?... :thumbs: |
